Mon, Jan 20, 5:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: How do I delete frames after cloth simulation?
Hamiltongraphics ( ) posted Thu, 02 August 2007 at 10:40 PM · edited Mon, 20 January 2025 at 5:12 PM
After a cloth simulation for dynamic clothing I would like to save just the finished frame so that I can save space on my hard drive.  Is this possible?  For example, I have 30 frames after my simulation and I only want to save the 30th frame, how can I do this?  Thanks, Jim
Conniekat8 ( ) posted Thu, 02 August 2007 at 11:03 PM
You can save the cloth part as a morph target, and you can save the character pose in the pose libraries  (I would do that to be on the safe side)
After that, you will need to delete all the keyframes preceeding the result that you want, so that the entire animation stands still in the frame you want. After that you can delete all frames byt the first one.
In case something gets goofed up in the process, you still have the pose saved and the final cloth sim frame saved as a morph target.
I'm not sure if there's any other way. Maybe someone else knows more :)
EnglishBob ( ) posted Fri, 03 August 2007 at 4:33 AM
The actual animation data is a minuscule part of the completed project: I don't believe you'd save any noticeable space by doing this.
