Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Yep, just had a discussion on Polyloop forums. Carrara hates .AVI for Vista systems that I read on Google searches, and it just won't work(unknown error on 2nd/3rd frame animations). The other standard BMP/GIF/JPG sequences etc. should work fine though, plus a few other formats/codecs from the net(Im still learning info about them).
Vista has a few updates to go before its works 100% with alot of things. Carrara may get a fix in C6 I hope. AVI works for most other 3dcg programs though, so its not all Vistas fault.
According to what I see, even existing .AVIs that come with my Carrara don't play in my Media player(I have Vista HB 64bit). It says the codec isn't supported or something.
I would suspect that this should be an easy codec fix by C6, or Vista hotfixes and service packs. There are a couple of newer Vista updates that mention AVI stuff, if you want to run your OS update(my Vista comp is not an online one, its a dedicated system and Im waiting for service pack).
I don't have Poser, Im still new at this, but others may be able to answer export question.
Hello I imported a pz3 scene from poser 7 into carrara 5 pro. It is basically Brutalis (the freak) doing a pushup.
When I render him he appears smaller and now has on this gigantic hat. Plus its a 120 frame scene and Carrara only renders 2-3 frames and then states an unknown error has occurred.
Please advise.
