This is very curious since I've tried 16bit in TIFF format. I can't see that it's resolution since that alone shouldn't make steps, infact i've sude the smoothing filter with curved surface to correct the problem to no avail. I also always use 4096x4096 and that doesn't help either. And why is it the steps always appear on the low parts and not on the higher parts of the mountain?
Are the low parts of your terrain flat?
If there is an extreme change in the normals or height it will contrast with the relatively unified normals/height of a flat area. Same stepping will happen on a plateau sometimes.
You could try trimming the lower edges off the terrain in the terrain editor, if nothing else works.
Friends don't let friends use booleans.
The only thing I can do is lower the steps part below ground level and use another flatter terrain in the same area and combine them.
Thanks anyway.
Edit: Just have to share this..... I've just worked out how to align objects like trees and rocks on uneven terrains, by clicking on the arrow button underneath the edit button LOL. Talk about a complete idiot, I was doing them all manually. :-D
How do I get rid of those horrible steps on the lower altitude slopes of the mountain terrain? I've tried smoothing but that just makes the whole terain look like molten custard.....
If it's because the terrain was made from 8bit greyscale images, would 16bit make any differance since i've just purchased Bryce 6.1 and not have steps, or is there another way to make a terrain without steps?
Thanks for your help. :)
