Thu, Jan 9, 7:58 AM CST
Subject: Copy and paste Parm Dials??
Eagle_hawke ( ) posted Wed, 15 August 2007 at 1:01 AM · edited Thu, 09 January 2025 at 7:30 AM
Does anyone know if theres a way to copy and paste Param Dial Values from a charicter to a clothing file with the same dials? I know you could go through them one by one but is there a way to copy all modified values at once and paste them all at once????
pjz99 ( ) posted Wed, 15 August 2007 at 1:08 AM
Yes, select the original object and then select any item in the Parameter Dials window (click the name)
Edit -> Copy
Select the target object and then select any item in the Parameter Dials window
Edit -> Paste
Be aware it will copy the ENTIRE properties pallette.
My Freebies
R_Hatch ( ) posted Wed, 15 August 2007 at 1:56 AM
You can also use the Animation Palette to copy/paste parameters for multiple body parts at once.
Eagle_hawke ( ) posted Wed, 15 August 2007 at 2:13 AM
Thank you I didn't think it was so easy
Angelouscuitry ( ) posted Wed, 15 August 2007 at 9:09 AM
R_Hatch may have the easiest way, but I think Ockham, or someone else in the Python Scripting Forum, also has a python to do that with Clothing.
But, yeah, just click the Pallette, and then CTRL-C.  Then switch the palette to the new set of parameters, and hit CTRL-V.  I do this all the time between the Main Camera and the Aux Camera(s), to get them into the same place.
