Fri, Jan 24, 4:45 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Poser to vue problem snce PPP update
martial ( ) posted Sat, 26 May 2001 at 6:00 PM ยท edited Mon, 13 January 2025 at 8:46 AM
Since i have installed the Poserpropack update i have problem when i export Victoria in obj format for importing it in Vue 3.1.It seems related to geometrie,may be the morph(just the standard ones);i have the same result with Vic2map and older vic map .Someone have seen similar problem?Thanks
bloodsong ( ) posted Sat, 26 May 2001 at 6:33 PM
heyas; that looks like some kinda weird bump map, maybe. check the material bump channel. it may be on upside down, or just have too much gain. poser bump maps should have like .03 gain in vue.
martial ( ) posted Sun, 27 May 2001 at 6:53 PM
Thanks .You are right.I have forget that PPP load jpg format as bump map so Vue import it and did not ask for when loading obj file.Before, with bum format ,when loading, i always check no when Vue can not load the .bum format and it cannot read,so bump map was not loaded.I have put no bump in Poser ,everywhere, before exporting and no problem with it in Vue now.Thanks for answering
