Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 27 6:56 pm)
I have to agree with the others hon. This set-combo is just other worldly gorgeous and this along with the new Thorne and Mada creation "Sojourner"... V4 not pretty? They can say that all they want but they are wrong. She's a wonderfully gorgeous figure and with your help and others she's, in my opinion, the best out there currently!!
Keep up the fabulous works!!
Richard ;-)~
---Wolff On The Prowl---
I purchased the COMBO Lillith package. The work is great, but I am having a problem with the character mat ( I think, I am new at this) , I am getting seams on both legs and in the left arm area. I have removed the package and reinstalled. Still problem with seams. This is a white line on both legs at the stocking line. Is there some way to remove this?
fhoaglan@hotmail.com
Hi:)
First thank you for your purchase:) I will be glad to help you with this issue. Are you using Poser or DAZ Studio? If your using Poser which version are you using? Do the seams show up after rendering? Seams may show while your in the preview/set up area but should not show at all once you render. I am sure that this has to do with your render settings. I use Poser 7 and am attaching a screen capture of the render settings I used for all of Lilliths promos.
When I used Poser 6 I always used the following settings:
If you have any questions on how to change your render settings please drop me a site mail and I will be more then happy to walk you through it:)
Renderosity's "problem Child"
Support Hydrocephalus research.. because a Shunt is NOT a cure!
Its very odd that your getting them:( as the product is tested specifically for seams not only by my own testers but by Marketplace staff here before its allowed to be sold. I await your images so that we can get her working for you:)
I rendered Lillth with your (Min shading rate of .2<) No seam lines. I was using a rate of 2.> As I said I am new at this. Will try to find out how "Min Shading" effects Firefly renders. Buy the way, is there informatiom on how each of the firefly render settings effect the output, or is this a hit and miss thing?
Thanks for your help!
fm
For me it was a hit and miss thing until I found a setting that worked best for me then I saved it as a preset. I am not really sure if there is somewhere that will tell you what each setting is for.. I will look in my Poser 7 manual when I get home and see if it discusses it there and let you know.
Just glad that your able to use her now:)
So I haven't purchased your fabulous pack yet but I'm still interested for a later time as she is really stunning. I work only in DAZ Studio. Has anyone reported seams when rendering there?? Can't have seams. I don't mind post work on occasion but not for fixing skin seams!!!
Thanks much!
RAMWolf.. I am by no means proficent in D/S but I can load her up and render her in it tonight when I get home and check for you so that you will know for sure. I have had no reports of seams on her other then this one but I am unsure how many of her purchasers have used her in D/S.
Thanks much. I appreciate that. Perhaps you should add a Studio beta tester to the mix to make sure you are providing at least minimal assurance to those of us that ony use Studio. Studio is continuing to gain users, appeal and popularity so why not just take the plunge and invest a little more time making sure your product works well enough in the program?? Doesn't mean you have to make separate shaders that are Studio specific!! Although my pal Fisty is really really good at that sort of thing!!
Well basically it works but your not going to get the same effects. Skin will be more shiny than how it would render in PP or Poser 7 because of the differences in the rendering engines!
Hellow RAMWolf:)
Now keep in mind that I am not an experienced D/S user.. I know basically just enough to open it.. load a character and render.. thats it..LOL That being said.. Lillith renders with no seams and is not shiny in the least (with either her default shader node mats (as I assume they dont load some of the shaders) or the NS mat (non shader node) or at least they dont with the defualt lights and render settings of D/S 1.7.1.5
HOWEVER.. there does appear to be some issue with the way the morph loads on her neck as it leaves a sort of ridge which is visable at certain angles yet not at others..
Hope this helps some:)
Thanks so much for taking the time. I'm sure the neck thing is a smoothing issue which is supposed to be addressed with 2.0 release I believe.
Thanks again!!
She's beautiful!
What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
Attached Link: Lillith for V4
With a beautiful custom face and body morph and a seperate morph for her ears Lillith can fit any render be it fantasy or realism. Be sure to check out her [ expansion package](http://market.renderosity.com/mod/bcs/index.php?ViewProduct=58302) for some darker more gothic textures or better yet the [ combo package](http://market.renderosity.com/mod/bcs/index.php?ViewProduct=58301) to get the best of both worlds!Renderosity's "problem Child"
