Download a freeware app called DocMemory. Create the DocMemory bootdisk, boot up your comp with it and check your RAM. It does thorough tests on your ram (with 128 itll take about 10 min to run through them a couple of times). The problems youre having could be caused by bad sectors in your memory corrupting your data.
Cheers! I shall go "hunt the app" and experiment, I'm pretty sure the drive itself is OK, (at least scandisk tells me so...) but I could replace it I suppose, it's a 20Gb 2.5 inch drive, but at the current rate of knots, I may a well buy a PowerBook G4 and have done with it. Anyone got any experience of running Poser on a PBG4? Does it work properly? later jb
My lap top PIII 600, 128Mb, Rage Mobility Pro 8Mb chipset, with 6.2Gb Drive, by Enpower, runs with Win 98SE. It has never failed that bad but I do worry about how hot it gets. Its always getting very hot and the fan is always kicking on. I've also noticed I must scan and defrag more often than on a PC. If I don't it'll go unstable. I've also noticed that if you reach the 1/2 way point on drive space it tends to hang up so I keep the drive free of extra files. Good luck.
