Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Not a silly question at all :)
When you buy a character package that has INJ, those files will change the shape of the figure. What they change depends on what the creator instructed them to change.
You do not need to add any of the V3 or M3 morphs to the figure prior to using the character package INJ files. The files will draw on the delta files in the !DAZ folder for the information.
Some change the whole figure including head and body with one click of the INJ file.
Others you need to INJ the head morphs and then INJ the body morphs, or vice versa. It doesn't matter which order you do it.
When you click "REM head", it removes the morphs that were injected and returns the head to it's default state. The same for "REM Body". Using that will remove the body morphs for that character package and return the body to it's default state.
Expression files are totally different. They don't alter the shape of the head. All they do is just add a facial expression.
Expression files should not be confused with "Face" files. Face files actually contain morphs and change the look of the whole face.
say." - Ghandi
Hi Friends!
Ok. IF i get this character who comes with it's own INJ for M3 or V3 and i put the INJ on the figure do i have to load all the others M3 or V3 morphs? Or only expressions if i will need it?
Because i noticed, when i INJ a character and i decide to remove the INJ the Morphs goes too! is that normal??
Should i put the INJ first and then the morps or viceversa?.... or it doesn't matter?
Thank in advanced friends!
AJ
Artist @ajmarti.com
