Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
The top line in this example is where the horizon SHOULD be if it was a longer lens - it's would be VERY compresses and almost image distortion at all.
The lower line is where the horizon actually BENDS downward. This isn't bad as the camera was properly levelled, but it DOES curve downward (lens distortion/curves straight lines) is a dead giveaway of wide angle lenses.
That is the only real giveaway as everything else in this shot is organic and can be shaped in any number of ways. But I would wager that the front face of the rock formation on the right is straight and vertical and not slightly angled forward (which is you vertical line giveaway).
Hope that helps. This looks like something one of the Meunch guys (David and Marc) would have taken - www.muenchphotography.com - their images are amazing!
-Lew ;-)
I don't know what to tell you about the lens Lew, but I know of a software solution that you might want to look into: http://www.kekus.com/software/plugin.html http://panotools.sourceforge.net/
Some photorapher really LIKE the lens distortion - I mentioned the Meunch family - they use it to their benefit and it actually enhances their images when they do (like this example of a Meunch image).
If you look at the original photographers portfolio he gives a description of what camera and lens were used for this shot. http://www.joecornish.com/portfolio/view.asp?pid=133§ionid=19&count=5
Comparing the two shots side by side this appears to have been taken probably on a dslr with a wide angle lens from the same spot. If it were a full frame dslr it coould have been something like the 16-35 or more probably due to the distortions noted above the 17-40.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
On the Lee filters site is another where he explains what filters were used
live;
sea in a Sieve.
Edward Lear
I known it's in German, butb this page by Sigma might be bhelpful:
http://www.sigma-foto.de/cms/bildwinkel/brennweitenvergleich.html
it shows you in Fleash a comparison between lenses from 10mm to 800mm, macro, converters etc.
You're shure it's a photograph, and not created with Vue, Bryce, WorlBuilder, Terragen or any other landscape soft? It looks rather unreal to me.
There are no Borg. All
resistance is fertile.
Okay, my math is a bit rusty - the Nikkor 90mm (any brand, really - it's just a size conversion for format) on 4x5 is roughly equivelant to a 28-30mm for 35mm film (in a nutshel, divide by 3? - a 150 is basically normal length for 4x5). Which would roughly be somewhere in he vicinity of a 17-20mm lens for an APS-C sized digital sensor?
That sound about right?
Sounds about right to me Lew.
I would guess he is using a 10-20mm lens and has had to zoom a little because of the filters used so as not to get any vignetting.
Who took it Eddie ? Maybe we could ask them ?
live;
sea in a Sieve.
Edward Lear
Granted the clouds are different than the ones in the add for Lee Filters, and different (as well as the lighting on the rocks) than the one for the FIRST Joe Cornish link, but it actually looks like all THREE versions were shot by him with hs large format 5x4 inch (I was saying 4x5 because i'm a pompous American and we refer to the smaller length first 4x5, 5x7, 8x10, 11x14 - get it?) Ebony (brand, not color) camera with a Nikkor 90mm lens.
It was in his description in his persnoal gallery on his site.
Elgol and the Cullin Hills lie on the Isle of Skye. Skye lies at the west side of Scotland, between the main land and the Outer Hebrides, rather to the North.
It was there that bonnie prince Charlie fled and was hidden after the massacre at Culloden, which makes many Scots still sing that "we can still rise up, and be the Nation again that stood against them, proud Edward (this was many centruries before Culloden, when the scots had won!) army, and sendthem homewards to think again.
Scotland is one of my dream destinations. You don't inhabit that land, you're tolerated by it. Pity the drive on the left. But ahhh... the Islay whiskies...
Back to this world...
It is Isle of Skye, Scotland.
You'll see the same beach in my gallery with a couple of cattle on it. This spot is just around the headland you see behind the cattle. A very popular spot to take photographs made famous by the Joe Cornish original. I've never had any good light when I have visited hence always refrained from even trying to make any captures along the rocky bit looking across to the Cuillins.
Sometime I'll actually stay in Elgol so give me more chance to get some captures from there in the evenings. It is a torturous single track road to get there and I don't fancy driving it much at night if the cloud moves in like it very often does.
Few weeks ago I spent a whole day on top of the mountain behind Elgol waiting for the right light to take a panorama - in the end all I got was wet as the rain swept in and I had pack up the gear to trudge back to the car .
live;
sea in a Sieve.
Edward Lear
