Thu, Jan 9, 7:04 AM CST
Subject: PPP obj imported in vue problem
martial ( ) posted Sat, 26 May 2001 at 5:52 PM · edited Wed, 08 January 2025 at 5:34 PM
Since i have installed the Poserpropack update i have problem when i export Victoria in obj format for importing it in Vue 3.1.It seems related to geometrie,may be the morph(just the standard ones);i have the same result with Vic2map and older vic map .Someone have seen similar problem?Thanks
Cheers ( ) posted Sat, 26 May 2001 at 7:34 PM
Hi martial As long as the right map has been applied or, the bump map scales are right in Vue (X 1.000, Y -1.000), then that could very well be a PPP bug. I must admit to not re-installing PPP since I last done a clean installation of my HD...I find it way too buggy at the moment. Sorry I could not be of more help :o( Cheers
Twitter: Follow @the3dscene
Varian ( ) posted Sun, 27 May 2001 at 9:59 AM
That looks related to the PPP bug that creates rectangular holes in objects. If you search back in the Poser forum, there are several messages that explain a workaround for it. Something about manually editing certain files to remove null lines. Or, you could export in 3DS and just apply the texture and bump when it's brought into Vue. I think the PPP bugs only affect the OBJ format.
martial ( ) posted Sun, 27 May 2001 at 6:35 PM
Thanks .I think the rectangular holes bug is sometime still there with obj format(sometime also i regret bying PPP)But Cheers seems to get right for my problem:PPP load jpg format as bump map so Vue import it and did not ask for when loading obj file.Before, with bum format ,when loading, i always check no when Vue can not load the .bum format and it cannot read,so bump map was not loaded.I have put no bump in Poser ,everywhere, before exporting and no problem with it in Vue now.Thanks for answering
