Wed, Dec 25, 1:24 AM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Question about getting sharper images
NightHawkRN ( ) posted Tue, 28 August 2007 at 5:50 AM · edited Tue, 24 December 2024 at 1:11 PM
I  have a Fujifilm 9100 9 megpixel digtal camera and have ordered a Canon XTI 10.1 megpixel camera. My question is how do I get sharper images out of these camera. I have set the Fujifilm to 400 ISO and the daytime images are clear but when zoomed in they pixilate badly. I have the image quality set at the max setting and the images are still not as sharp as I would like them to be. This is getting really frustrating. Does anyone have any tips, tricks, or hints?
Thanks in advance for your help.
ejn ( ) posted Tue, 28 August 2007 at 6:27 AM
Is there a sharpening option in the menu some where.
My first digital was an Olympus and everything looked upsharp to the point of what looked like out of focus but on checking the menus I found that sharpening was set to normal and when I chose a sharper option the pics where OK.
maybe Olympus think out of focus looks good?????
Eddie
TomDart ( ) posted Tue, 28 August 2007 at 7:01 AM
I do all of my sharpening in software on the pc.  Sharpness is turned off in my camera. Why? To avoid halos that sometimes pop up on certain sorts of shots..and I prefer to sharpen myself.
As far as seeing the pixels, you can only zoom in so far and then the pixels show...regardless of "sharpness" of the image.   Sorry, I didn't help much with your question.
Tanchelyn ( ) posted Tue, 28 August 2007 at 7:24 AM
When you take pics in lower light conditions, you can encounter situations in which you have to up the iso, indeed. But you can compare this to a very silent passage in music, barely audible, and when you up the volume of your amplifier, you hear it better but you get a lot of noise and hiss from the ampli with it. The better your ampli, the less problems you have.
Same goes for camera's. You'll always meet some  "no tresspassing" sign somewhere where your camera is at its maximum performance. Beyond that, you get noise.
There is software to reduce it, but that usually goes at the expense of a bit of sharpness.
I personally also never use any settings on the camera to sharpen, enhance etc as it's never as good as when done afterwards.
So, for sharper pics:
-see that you have more light
  • use a tripod
  • lean against a wall, or find some support to limit body trembling (heartbeat, muscle tension etc)
  • experiment what your camera can do and what not. and be creative withibn the limitations.
  • eventually use a flash. I never do, but that's personal.
There are no Borg. All resistance is fertile.
bclaytonphoto ( ) posted Tue, 28 August 2007 at 7:40 AM
Use the lowest ISO when ever possible
www.bclaytonphoto.com
bclaytonphoto on Facebook
TomDart ( ) posted Tue, 28 August 2007 at 7:56 AM
Are you talking about zooming in on the LCD viewer or on a computer?      The mgs of the cam are more about print quality and size than computer view, which has a set resolution regardless of the mgs of the image.
I do what the others here say: Steady to avoid shake fuzzies and lowest ISO posssible with short exposure times to avoid image noise.
awjay ( ) posted Tue, 28 August 2007 at 9:05 AM
i use 100 iso usually ...200 on really sunny days.....
olivier158 ( ) posted Tue, 28 August 2007 at 9:29 AM
hey ;o)
  • use 100 or 50 iso if possible
  • work in raw if possible
  • don't zoom too much
  • close two aperture to obtain the best of the lense
  • don't shoot without tripod if the speed is less than your focal (ie. shoot at 1/60è s. with a 50mm, may be 1/30è, but sharpnes is not guaranteed anymore - 135mm -> 100è s or 200è s, etc)
in photoshop, use the 'unsharp mask' ... but be cool with it !!!!
last, could you please put a sample here ?
hope this help !
TwoPynts ( ) posted Tue, 28 August 2007 at 10:58 AM
Olivier provided a good list of ways to get the sharpest image possible. One thing to rememer is that when viewed at 100%, no image is going to look overly sharp, esp. from a 9MP camera with a small sensor.
bclaytonphoto ( ) posted Tue, 28 August 2007 at 4:55 PM · edited Tue, 28 August 2007 at 5:03 PM
Ok..I just re-read the original post...I bet the camera has a digital zoom...
NEVER USE DIGITAL ZOOM
always try to stay in the optical zoom range..Usually there is something that indicates when you get into digital zoom
I checked DP preview, and yes it does go to digital zoom..
[http://www.dpreview.com/news/0608/06082412fujis9600.asp
](http://www.dpreview.com/news/0608/06082412fujis9600.asp)I also read it will shoot at ISO 80..try some day-light shots at that setting and stay out of digital zoom..
It also say's that you can shoot in RAW, which was also suggested previously.
It looks like it has a nice 10X optical zoom...that should get you pretty close..
let us know how you make out with this..
promiselamb ( ) posted Tue, 28 August 2007 at 7:51 PM
*"I have set the Fujifilm to 400 ISO and the daytime images are clear but when zoomed in they pixilate badly."
WOW  I alway shoot at ISO 100. and I have only used ISO 400 once and that was shooting at night and if I use a high ISO like that then I get pixels bad I dont get bad pixels with ISO 100 at all. then I sharpen in photoshop
I shoot Raw canon rebel xt
TwoPynts ( ) posted Wed, 29 August 2007 at 7:46 AM
Yes, if you were in your digital zoom range, that would certainly be the main cause of pixelation and non-clarity. Fuji's are known for good higher ISO performance, but as Miranda states, try to always keep it as low as possible.
lesbentley ( ) posted Tue, 04 September 2007 at 7:17 AM · edited Tue, 04 September 2007 at 7:22 AM
Others have said most of it already, but here is my take.
The two main factors in an unsharp image are ISO speed, and camera shake. these factors work in opposition to each other.  The slowest shutter you can use without noticable shake will depend on how stesdy your hands are. With the camera set to shutter priority, try a few test shots  at diffrent shutter speeds in your back yard to finde your personal limit. Once you know your limit use the lowest ISO compatable with that shutter speed in any given circumstance.
A tripod can be cumbersome to lugg around all the time, a good compromise is a monopod with a quick release fitting. I always like to take one when I go out with my camera.
If you resize your photos on a PC the the very act of resizing will decrease the sharpness, even if you are reducing the size. As well as the sharpen filter, a clarify filter, or more contrast, can add to an impression of sharpness, even though the image is not actually any sharper.
Of course getting the focus right is another factor, sometimes auto focus can focus on the wrong thing, and you have to switch to manual.
prixat ( ) posted Sat, 08 September 2007 at 3:29 PM
I got myself a monopod. A Hama star 78, its taller than I am! At £9.99 I could not resist. Now if someone could explain why it has a rotating head???
regards
prixat
TwoPynts ( ) posted Mon, 10 September 2007 at 3:12 PM · edited Mon, 10 September 2007 at 3:16 PM
Congrats! I'm still trying to figure out the rotating head part, though I assume the tilt feature is for enhance control, so you don't have to tilt down the whole shaft.
danob ( ) posted Wed, 12 September 2007 at 5:23 AM
Seems you are asking two separate questions here are the images not sharp? or is it the grain thats a problem.. Some great advice given here, but may well disappear when you get the XTI but even then sharpness is often more to do with lens quality, and noise with the sensor..
To get the best results you need to ensure you have the best camera settings for the given light conditions.. Usually the lower the ISO the better... Postworking images also depends on making sure you have the right camera profile for the software you use..
Danny O'Byrne  http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
