Tue, Nov 26, 11:51 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: pzs for local files
AndyCLon ( ) posted Wed, 29 August 2007 at 3:04 PM · edited Fri, 26 July 2024 at 7:33 AM
In P6 is it possible to make the PZS file work with local files?
I've tried the following but Poser seems to ignore it. I know it can launch other local files because it launches the main help files into Acrobat without issue. I've also ensured that this path works in IE.
file:///G:Poser6TutorialsTest.pdf
Ideas, suggestions?
PhilC ( ) posted Wed, 29 August 2007 at 3:11 PM
Close :)
try file:G:Poser6TutorialsTest.pdf
AndyCLon ( ) posted Wed, 29 August 2007 at 5:00 PM
No luck with that either. :(
PhilC ( ) posted Wed, 29 August 2007 at 5:16 PM
I'm using this:- file:C:Program Filese frontierPoser 7Python for Poser by PhilC.pdf
Saved as the file
C:Program Filese frontierPoser 7RuntimeWeblinksPhilCPython for Poser by PhilC.pzs
And for me its working
ummm?
Is G: an internal drive?
AndyCLon ( ) posted Wed, 29 August 2007 at 5:21 PM
Yes G's internal, I'll try with other drives in the morning.
Could be a Poser 6 limitation?
