Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
How are you bringing it into Carrara? If you use the native importer, it will not show up. Dynamic cloth can only come in using Transposer. I think it's included with c6Pro. I haven't downloaded my final C6Pro yet but Transposer was working fine in the last Beta - on P6 and below that is. It won't work with P7. Mark
Thre are new mesages posted on the DAZ|Carrara forums stating that Transposer is NOT part of the C6 product or upgrade.
You can purchase Transposer 2 for C6 as a separate product (add-in?) - listed at $99.99, but currently discounted. It will NOT work with Poser 7 files.
Bummer!!! Personally I thought it should have been included with C6 Pro - or upgrade, since It alreadty came with C5 Pro.
when you have poser 7 (or poser 5, 6)
you can manage to import dynamic cloth with the help of a python-script, that converts dynamics in morphs.
the following link at daz3d shows, how it works:
http://www.daz3d.com/i.x/tutorial/tutorial/-/?id=1543
but don´t forget to delete all lights, before you save your pz3-scene!
hope it helps.
bine
I work with poser 7 but have my runtime in poser 6 - it works perfect for carrara 5 with the transposer 2
but I dont understand the the difference between the new transposer (its still transposer2) may somebody can explain it to me in easy words....
and i cant load older sences - is that a problem about the transposer?
Hey there!
I've run into a problem with Carrara 6 Pro and I was wondering if anyone else has run into it or has a workaround.
I made a dynamic cloth animation in Poser 5 on a V3 model. I saved the file, went to import the scene into an empty doc in Carrara, and lo and behold the model vanished! However, the scene list on the righthand side still listed all of the model's body parts as well as different components of the dynamic cloth. In the objects tab, only the props mated to the V3 model showed up, but the V3 model itself was absent both there and in the 3D view. Also, the animation seemed to have vanished as well from the cloth model (and I did make sure that the 'import animation' box was checked when importing the scene.)
I've tried more than one of my old scenes that imported fine into Carrara 5 Pro and gotten the same odd result every time with Carrara 6 Pro.
Is there something about Carrara 6 Pro that I'm missing here?
