Thanks. Now that I've tried it and found it works, how do I get it to cough up the Edit function on boolean/grouped objects? I'm trying to make the object in this picture, which was done in Infini-D. Infini-D will only do it in render mode, and won't output the object with holes in it (limitation of DXF I assume).
How do you convert a Bryce OBP object into a Wavefront OBJ? I looked around for a utility, but didn't see one. I also tried exporting things attached to terrains, hoping that the 'thing' would go out with it, then I could just open it in another program and separate them, but no luck. So how's it done? Newc
