Vue F.A.Q (Last Updated: 2024 Jun 25 7:29 pm)
You need to use very high anti aliasing settings. Using the soft antialiasing strategy helps too. Also, it's good to delete bump from distant objects/trees if they are not seen too close, it will reduce the flickering, grain, and speed up render times.
In the advanced animation parameters window, you can also define a distance blurring. If you use this, use a very low %, and a small radius, otherwise it will be too blurred.
I suggest you buy one of the scenes from Philippe Bouyer at Cornucopia3D, he's responsible for the demo reel of Vue6Infinite, so you can learn more about animation in Vue. They are very unexpensive, and highly informative.
how do i get rid of flickering in shadows?
i have vue infinite 6.5 and i've been tweeking some values with no result
the tree shadows keep on flickering...
please help me
