Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
obj2cr2 by philc
However, there is no magic solution. The success of a conforming clothing item depends on how the mesh topology is created, the grouping, and some tweaking of the joint parameters.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
Quote - Know any other software that does the conform better, without the need to modify the joint parameters?
Not really. In this case there's no shortcut to knowing how to do it by hand, if you want it to turn out well. Even with Phil C's wonderful utilities, there's hand tweaking to be done.
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Hy there!
Do you know any software that will transform your models into conforming clothes?I already use QuickConform, but you have to modify the joint parameters in Poser so your figure will conform properly and this can be a tedious process at times.Know any other software that does the conform better, without the need to modify the joint parameters?
I have checked the thread for conforming clothes already and the software from that thread does not seem to be on sale anymore.
Thank you in advance!
Best regards!
