Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
watch the movie demo. It is sooooo easy and fun. You can load your own faces or anyone elses.
Click here to watch demo!
Feel free to ask questions.
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Thank you Anton, can't wait to try it out!
There are a lot of things worse than dying, being afraid all the time would be one.
i guess I'm blind, but where is the download link for this?
I've looked over the pages, but cannot find it.
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
The download link for FaceInterMixer is on Apollo's main download page, within the right column of the main download table.
If you have never used python before or are unfamiliar, don't be. Python allows direct access to Poser's functions. Watch the movie demo. By simply browsing and loading the script, the interface is very easy to use and walks you through everything.
You can use FaceInterMixer to make create new phonemes, shaping morphs, etc for Apollo or characters lacking them; assuming those characters have some morphs to work with.
Faces are easily saved right back into the face library as you normally would.
Summarily, the problem with face files (.fc2) has been they are basically static; unmoving. People use morphs because they are easily turned. This script free the face file and makes it fluid and adjustable without pain or headache.
Don't just download it and stash it in a dusty folder. Open it as play with it. You will be so glad you did.
Will it work with any other character besides Apollo?
DPH
It will work on any Poser figure with a head group, wether human, animal, toon, robot, enviorment, etc etc.
Just read the last part of the main post under "Editing the script for use with other figures"
You just open the script in a word processor. Always edit a copy only. thn.
You be sure to place all the face files you want to use in the same folder. Once the script is running you can browse and load a face from any folder.
Try it. Just playing with it is infinately easier to understand. The readme says the same as above. Or just pop back and feel free to ask any questions.
If people want to edit the script with their own slider faces, or for other figures, and want to share them, I can set up a FaceMixer freebie section on Apollo's download page. Noone else can redistribute the script.
I need to host the zip on my own server, but just zip and send me the script, face folder, and a readme.
The readme should have the name of the folder, the list of faces in it being used, and your email address.
yes just read the password from the red text right above the blue download table. You saw it, just didn't realize it.
If you still don't see it do a page search for the word "Password".
Also there is a FaceInterMixer thread at CP in the Apollo forum with info and pics.
The FaceInterMixer script for Poser
**Making faces just got a lot less random!!!
Your mini face room for any Poser figure with a head.**
Anton's FaceInterMixer
Concept and Design by Anton Kisiel
Code by David Drumright(Occam)
For Poser5, Poser 6, and Poser 7 and above; not P4ProPack.
The FaceInterMixer is a python script, used within Poser,
that allows the user to load Poser .FC2 Face Expression
files and use them in Poser as if they were morph targets.
There is nothing random or averaged out in the script. You
have complete control. And you will love it. You can use
face files to make new expressions, new shaping morphs,
new character faces, ethnicity, monsters, etc etc etc.
In the same way you use FULL BODY MORPHS to mix characters,
this script allows you to mix face files with a separate
and independent slider for each face file.
Easy easy fun. Can be used on ANY Poser figure with a head
and morphs. Animals too!
All rights reserved. Not to be redistributed.
------------The Interface------------
The interface that is created resembles the dials palette
for the head, but instead of morphs dials you can turn and
reverse, you have sliders for any face poses you want to use.
The interface sliders will update the head morph dials on the
figure, but you can also still use the morphs on the head, as
well as the sliders on the FaceInterMixer.
When the script is closed, the last face morph values you
created, with the sliders, remains on the figure.
SLIDERS:
The sliders, which load zeroed, can double or even reverse
the effect of each face on each slider. Next to the slider
is the name of the face pose loaded; blank if the slider is
empty.
At the other end a "load..." button allows you to
load any face files you wish to use. When a new face is
browsed and loaded, the values are read and then all sliders
are zeroed.
Below the main sliders is a lone master slider, called
"Intermix Power", which can multiply the overall strength of
the entire intermix being calculated by the interface.
Sliding the slider to the far left, like the other sliders,
reverses the total effect.
BUTTONS:
At the bottom of the interface, are three buttons. The first
button, called "Memorize Face", will set whatever is currently
dialed up of the interface and set is as the default face
restored to when you use the second button, ""Reset Sliders",
which zeroed all the dials and returns the figure's face to
the state is was in when the script was launched.
The last button, "Quit", ends the script.
------------Using FaceInterMixer------------
LAUNCHING THE SCRIPT:
First launch Poser and load just Apollo. Be sure no ADS
scaling or FBM's are active. Just default Apollo.
Then, under the "Windows" pull down menu, select "Python
Scripts" to open the Python buttons. Click an empty slot and
browse up one folder and delve into the "Anton'sPoserScripts"
folder. Then delve inside the "FaceInterMixerApollo" for the
"FaceInterMixer.py" python script.
Any face loaded onto the figure, before you launch the script,
will be the default reset face until you use the "Memorize
Face" button.
So, now that both figure and script are ready, click the button
to launch the FaceInterMixer script. If the figure head is not
behind the interface window, you will see each of the faces
being read. Allow the script to load the faces. When it is done,
the sliders will appear and you can start playing.
SAVING FACES:
At any time, while using the FaceInterMixer script, you can save
a face into Poser's Expressions(FACE) library.
USING FOR ANIMATIONS OR JUST THE ANIMATION TIMELINE:
Any action on the interface will create a keyframe of the Poser
Animation Timeline. So feel free to use FaceInterMixer for your
animations too!!
EDITING SCRIPT FOR USE WITH ANY FIGURE:
(NOT to be redistributed ever.)
If you open a copy of the FaceInterMixer Script you will see notes.
Basically, you edit the folder name to point to any folder
containing the faces you want loaded on launch.
Then you put just the title of each face pose (.Fc2) into the
slots in the order you wish. You can leave some blank if you want.
Remember, the script can only hard code launch faces from one defined
folder. So be sure all the faces you list are in that folder without
typos. But once the script is launched, you can load faces from other
locations for that session.
If you enjoy this script, please show support and spread the word.
http://www.antonkisieldesigns.com/~a...umanfigure.htm
"Conviction without truth is denial; Denial in the face of truth is concealment."
Over 100,000 Downloads....
