Sat, Feb 1, 5:09 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Quick question - duel processors
ashley9803 ( ) posted Thu, 27 September 2007 at 6:06 AM · edited Sat, 01 February 2025 at 4:41 PM
On all previous renders in C4D I get two rendering regions (bars) rendering down at the same time. I assumed that these were each processor rendering seperately. Perhaps I'm wrong about this.
On the render I'm doing at the moment, it is just rendering top to bottom like Poser.
What's happening here?
Thanks in advance.
MarkBremmer ( ) posted Thu, 27 September 2007 at 6:13 AM
Make sure you you have Multithreading enabled. In Carrara, renderings are done with tiles. You'll see different colored tiles for each processor on the job. (or just gray ones if you're using additional render nodes) Mark
ashley9803 ( ) posted Thu, 27 September 2007 at 6:13 AM
Oops, posted to the wrong forum, but I suppose the same question applies to any program that can use duel processors.
ashley9803 ( ) posted Thu, 27 September 2007 at 6:19 AM
Thanks.
I haven't changed any setting, but how can I check the multithreading thing?
MarkBremmer ( ) posted Thu, 27 September 2007 at 6:26 AM · edited Thu, 27 September 2007 at 6:27 AM
Can't help you out on the C4D thing. ;-) In the render room in Carrara, its under the Rendering tab in the Misc. section. Mark
ashley9803 ( ) posted Thu, 27 September 2007 at 6:31 AM
Thanks again. I guess C4D has the same options. Will check out once this painfully long render finishes.
Miss Nancy ( ) posted Thu, 27 September 2007 at 12:10 PM
p.s. mark - I noticed that the last animation I did was rendering each frame thrice. then I looked at render options and found I had inadvertently checked motion blur. the effect isn't very noticeable, but it makes the animation look more natural than one without blur.
