Do the PZ2 files look proper? Open brackets matched by closing brackets?
Does the figure have any duplicate names, like a frame named "body"?
If all else fails, try removing all the "staticValue" lines from the PZ2.
In P7, I've seen a pose that fails to hold because the "staticValue"
lines were causing the figure to return to its default.
My python page
My ShareCG freebies
No Duplicate names or staticValue line. However there was a refFigureJamesG2 lines with a figure and associated body parts and a thighlength=0 reference which I removed. The two poses are towing position (legs together) and firing position (legs splayed). the firing pose took but the other didn't and looking at both pose files the key values were exactly the same. Changing the key value in the tow file allowed both poses to take but when you try to move an individual leg and then apply the pose again they kick everything out of kilter . Sorry if I'm not explaining everythin clearly but its easier to see whats happenning than explain it.
Hmm.... Sounds sort of like an Inverse Kinematics problem.
I don't know if the gun was built with IK chains; it probably
shouldn't have been built that way. If it does have IK, you
should certainly turn off IK for all the legs before doing any posing.
My python page
My ShareCG freebies
That's truly a puzzle. Could you show some screenshots, including the hierarchy window?
Might help to get better answers........
My python page
My ShareCG freebies
I am trying to save poses for an artillery gun which are basically the firing and towing positions but although the poses are added to the pose library, when I try to apply either they don't take. I am adding them through the add button in the library and have used every option but they just don't take. Is it me or is it P7? Any help would be appreciated. The gun is a figure not a prop.
