I have a similiar question. I know I read back in my Practical Poser 6 book about the ball that comes with clothing so you can adjust to clothing when you change the size of a figure. Sadly, I havent been using Poser for a few long months and my 2 yr old misplaced my book. :crying:
My question is... if I make my V3 bigger in the thighs, what do I do with the green ball that's in the middle of her legs to get the clothes for a regular V3 linebacker figure to now fit to her voluptuous figure?
Wardrobe wizard madde by Phil C will read the morphs from the figures, and create clothing morphs to fit the figure morphs.
People with Poser 7 like to use morph brushes to fit the clothes. Maghnets can be used in p6 (I find them a pain)
There's another utility, morph something (i'm mind blamking on the name, sorry) that works with some of the basic clothing, when the body and clothes meshes are very similar. I only tried that one once, and failed misrably LOL
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Morph Magic can load morphs into clothing. I have used it a lot for adding the D3D and RDNA morphs to clothing for TY2, Miki 2, Poser 7 and G2 figures. I haven't actually tried installing any of my own morphs, but I assume it would work just as well for that. I've had the odd oddity, but mostly it has worked successfully.
One important difference between WW and MM is the fact that WW works inside Poser and MM doesn't. Some people prefer WW (partly) for that reason, I believe, but there are advantages both ways. I think WW requires more planning for a complex scene. Once you have two characters, known to WW, in a scene, I don't think that it has a way to identify the character which is the intended target. I'd love to be wrong about that, by the way, so please correct me, if appropriate. With MM, you go outside Poser, load the character that contains the needed morphs and thansfer them into pieces of clothing. It can take a while and the files created can be very big, with implications for Poser's performance.
I like both and use both frequently.
I have been looking at WW but have not come across Morph magic yet, where can i find it!? and is it free or a purchase product!?
Thanks for your help! I was hoping poser could do it itself :D
Morph Magiccan be found at DAZ,I was quite happy with it untill I found out,it won't work for Victoria 4.1, It did for V4.0 but after the upgrade it didn't I sent a support ticket to markdc (who made it,but I didn't got an answer so far. I works well with V3. haven't tried others.
regards,
Bopperthijs
My experience with clothing a morphed figure ( while still not being a tech-wizard about these things):
Used M3 with Bishonen morphs by Tifft478. Saved the morphed figure into my Library characters palette ( Figures).
Used Wardrobe Wizard by PhilC, converted clothes from M3 to BishonenM3 figure. Also managed to convert clothes meant for other figures to M3Bishonen morph figure. not 100 per cent sucessful each time, but with some tweaking it would work.
Eternal Hobbyist
Is there any way to save your custom morph dial settings so that you can apply them to your clothing and not spend ages just fitting clothes to you morph!?
Thanks for reading, hope you can help.
