Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 17 3:50 pm)
I parchsed It.
Good:
1.Ease to Use
2.seems Stable
3.Selectable output (textuer or add on figure)
No-Good:
1.Cannot put Decals to Prop? (I need to put Decals into Hats and Caps)
2.Cannot put Decals over Materials using Same Texture?(I need to put Big Decal to front of T-Shirt)
3.Cannot Mirror Decals?(Sometims I need to put Decals Each side of figures)
4.(Critical) on Configuring, Decalmaster cannnot found my "Japanese Edition" poser runtime.
I had to reweite config file manualy, need "browse manualy" to select runtime.
5.Too Slow to Browse "Huge" runtime to Select Fighers and MATPoses
6.Cannot read "Non-jpeg" texture (my favoriate A3 texture was PNG)
Many claims, but Totaly I love this tool thx.
Soon on Marketplace would be available the newer version: DecalMaster v1.1.
In the meanwhile who already bought DecalMaster v1.0 will receive, free of charge, the upgrade to the newer version (maybe some delay on the weekends).
Changes from v1.0:
I purchased your product the other day for $34.95. I see it's priced at $31.45 now, I guess my bad luck.
I have version (V1.1.5.3) and all looks good so far, renders in P4, but not with firefly. The *Body.jpg is good and when I render with firefly " NO DECAL " is on my figure.... This is a wonderful product, but I need it to render with Poser 7 ( autosetings and manual tried ) both fail with fireFly! Looking at the promo I can not see P4 only..
fm
I don't know why the rendering on P4 works and in P7 doesn't...
DecalMaster does not require a particular Poser version because it generates only the textures and does not integrate at some higher level: you can use the generate textures for example in every other 3D modeling program that loads OBJ geometries and JPG images.
Anyway, I will investigate to try to solve your problem, so you can post some beautiful image!!
Attached Link: DecalMaster on MarketPlace
![file_389722.jpg](https://live.cdn.renderosity.com/forum/threads/2714590/file_389722.jpg)
[ DecalMaster](http://market.renderosity.com/mod/bcs/index.php?ViewProduct=59686&vendor=295677) is a standalone utility for editing your textures with drag&drop operations. Don't spend a lot of time hand-editing your texture to place a tatoo on the deformed skin: use [ DecalMaster](http://market.renderosity.com/mod/bcs/index.php?ViewProduct=59686&vendor=295677) and all scaling/deformation work is done for you! You only need to prepare a 2D image to "stick" on your model!
