1> Turn Shadows on for the Light that you want castin Shadows
2> Turn on Cast Shadows under the parameter window of the object you want a shadow of
3> Turn on Cast Shadows under your Render Settings
4> Aim Shadow casting light at Shadow making object and render.
You folks got me interested in this so I tried it with a ground plane and a sphere resting on it. When I set the sphere to invisible, no shadow even with shadow activated. MatrixWorks' steps work. However, one more thing you can check is the shadow intensity of your lighting .
IIf the shadows are set too low the shadows won't show well. eg a setting of decimal 2 (.2) will give an extremely faint shadow while a setting of one (1 ) gives you pure black. Try eliminating all lights except one. Set the intensity of the shadow to one (1) in the lighting controls and see if you got the shadow, then reduce the intensity to your taste. I have Poser 5 and it works just fine-Plutom
Maybe older versions work different, I dunno ^_^
I used a prop floor from the free stuff and I cannot for the life of me get shadows to appear on the floor - I tried making the ground plane invisible and nuthin- I can not remember how to get the durn shadows to appear - I do not want to use a shadow catcher if I do not need to- HELP- oh yeah -poser 7
