Mon, Feb 3, 9:47 PM CST
Subject: props and enlarging characters
WLC ( ) posted Thu, 31 May 2001 at 10:03 PM ยท edited Mon, 03 February 2025 at 6:57 PM
  1. Is it possible to remove a prop from one character to another. When i try the whole charater is moved with the prop or when i delete the original charater the prop i moved is deleted with that charater. 2. Is it possible to enlarge a character after clothes and props are attatched. When i try to enlarge a charater i created the clothes and props does not enlarge.
Cybermonk ( ) posted Fri, 01 June 2001 at 8:30 AM
Sounds like the prop is apart of the figure. Thats all right though. You can get it anyway. Export the figure as an obj. In the export option dont check weld anything. Also a good Ideal to preserve object names as it'll help you find what your looking for. Now reimport the obj. Select the figure and then use the grouping tool to spawn prop. This will break the whole thing in to it's component objects. Then just delete the parts you don't want. If the prop your after is broken into multiple parts just re-export. Again don't weld anything. This will leave you with a prop that has sub groups of objects that can be selected and textured differently. Hope this helps
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
