Fri, Dec 20, 11:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Render problem.
Torulf ( ) posted Tue, 16 October 2007 at 5:35 PM · edited Thu, 25 July 2024 at 11:57 AM
I am making a poser movie.
Win 2000, 3,2Mhz, 2Mb memoy.
I using P7, James HiRes, V4 and some props.
Firefly render, no ray trace, 3lights
Render to BMP images.
Reytrace bounce 2
Irradiance changing 50
Pixel samples 4
Min shading rate 2,09
Max bucket size 45.
Frames 640x480 25 f/s
I got this error message. I have already decreased Max bucket size from 60 to 45.
What would I do? Grateful for help.
TG
Kaji ( ) posted Tue, 16 October 2007 at 5:46 PM
Did you try rendering in a separate process?
vince3 ( ) posted Tue, 16 October 2007 at 5:46 PM
have you tried calling poser all the names under the sun yet?
Kaji ( ) posted Tue, 16 October 2007 at 5:47 PM · edited Tue, 16 October 2007 at 5:47 PM
Quote - have you tried calling poser all the names under the sun yet?
Poser works better when you sacrifice a goat in its name. Er. :)
MegaJax ( ) posted Tue, 16 October 2007 at 5:55 PM · edited Tue, 16 October 2007 at 5:57 PM
I think I used to get that error message, before I changed my bucket  to 8, that seemed to have solved the problem for me.
Torulf ( ) posted Tue, 16 October 2007 at 6:35 PM
I do not know how to use separate process.
I are tet a smaler bucket first.
TG
Kaji ( ) posted Tue, 16 October 2007 at 6:43 PM
Under Edit -> General Preferences Click the Render Tab Check Separate Process in the Render Process Box
kathym ( ) posted Tue, 16 October 2007 at 7:20 PM
Looks to be the typical one i get when I run outta horsepower.
Just enjoying the Vue. :0)
Torulf ( ) posted Tue, 16 October 2007 at 8:20 PM
Thanks! Ihave sett the bucket to20 and itt works well.
I want to test the "Separate Process" method and look if its gives fastaer render.
TG
JHoagland ( ) posted Wed, 17 October 2007 at 10:35 PM
Lowering the bucket size usually helps. :)
When you click the option to use separate processes, be aware that Poser will use more of your memory. This means you probably won't be able to do anything else with your computer until Poser finishes... including "little things" like answering e-mail or writing notes in NotePad.
VanishingPoint... Advanced 3D Modeling Solutions
