Photography F.A.Q (Last Updated: 2025 Jan 22 8:17 pm)
Pretty nice job, at the resolution it is at i cant see any glaring mistakes (i had a look at the doctored shot before looking at the real one justto see if i could work out where the cloning was). Anyway, after i had a comparison one thing came to mind... the "scaffolding" which holds the wheel under the wing: should there not be a gp on the right side... ie is there a person standing behind blocking the concrete coming through to outline the structure like on the left side of the "scaffolding"?
Minor thought because i wouldnt have noticed it without the original
"In every colour, there's the light.
In every stone sleeps a crystal.
Remember the Shaman, when he used to say:
Man is the dream of the Dolphin"
Rich Meadows Photography
If you bring a tripod to these events, just shoot several shots, layer them in PS and remove tourists to reveal the blank spots. You'll need more pictures when it's very busy, but with some luck there's a blank spot for everyone in one of the photo's.
What is a friend? A single soul dwelling in two bodies. -
Aristotle
Glass Eye Photography =- -= My Rendo Gallery =-
You did an excellent job.
Sometimes when I need to clone a larger than normal area I'll make a copy of a "clean" region near the "contaminated" spot, move it over and glue it on. Sometimes I'll alter the orientation of the copied part or alter the transparent or opacity property. The often leaves slight edges, but they're easy to take care of with the Clone tool.
The reason I do this is that, at least for me, sometimes the clone tool ends up reducing the texture of the background, and a copy/paste helps to bring in some of the underlying texture from a nearby region.
Sometimes this just won't work, or it doesn't matter, or I have been able to get away with fewer dabs of the clone tool which will move around but not smear the texture.
I don't see this as a problem in your image, it just brought the copy/paste/clone edges method to mind for me.
Anyway, today I got a really cool shot of a C-47. I loved the lighting and POV. But the crowds and delineators/caution tape took away from it. So I tried my hand at the good old clone tool. After about an hour.. here is where it ended. I plan to post the final in the gallery. Let me know if you see any glaring mistakes please.
This isn't to toot my own horn on my skill.. more to show what some paitence can do to save a decent shot.
Thanks, Bruce
Click for Full Size
