Forum Moderators: RedPhantom
Actually, ...
REM stands for REMember what you were trying to do immediately before the 'puter crashed.
and ...
INJ stands for the INJury that you sustain after banging your head against the 'puter screen after you can't REMember what you were trying to do before ...
cheers,
dr geep
P.S. @ MegaJax ... Please stop disseminating false and misleading information. (jk) ... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
LOL @ Geep.
It means what MegaJax stated.
You would add the file to your runtime as usual. Double click the image for the INJECTION pose you wish to use. Example: "Inj fullerLO lips". You won't see full lips on your model just yet. What you do, is go to your document window, and if you're currently in the "head" of your figure, click on another part...like body, then go back to the head. It's a refreshing...if you will, then you'll see the new dials in the parameters window. You spin them and then you'll see your image change. REM will remove that dial if you find it's not needed.
First things first...
Do you have the V3 morph packs from DAZ? If not, most of the INJ-REM poses won't work on your figure.
The free version of V3 comes with hand scaling, a few expression morphs and nothing else. You need to buy the Head and Body morphs from DAZ if you don't have them already.
The + is generally used to indicate the morphs will be added to your character. That is, as long as you have the morphs installed.
You're not "refreshing" the picture in the document window itself. You know where your parameter's dials are right? IF you don't, let me know and I'll make a screenshot.
But if you do, after you INJ by double clicking, you have to leave a body part in your document window, and go to the body part you wanted to apply the morph to, so that you see the injection appear in the parameters window. Refreshing...by leaving the body part, won't make it appear on the V3 itself. It will just make the dials appear in the parameters window. Then you spin the new dials and the morphs occur.
The V3 is from DAZ! Yes, I think I know where the parameter's dial are. But if I double click on this picture (preview) nothing happens. If I want to change the expression of the face, so I have to do it manually. I thought that if I double click this preview-picture the face e.g. would change exactly in this position automatically. But to be sure, make a sreenshot!
I don't need to ... DAZ has the answer right here.
http://www.daz3d.com/i.x/tutorial/tutorial/-/tutorial?id=763
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Quote - The V3 is from DAZ! Yes, I think I know where the parameter's dial are. But if I double click on this picture (preview) nothing happens. If I want to change the expression of the face, so I have to do it manually. I thought that if I double click this preview-picture the face e.g. would change exactly in this position automatically. But to be sure, make a sreenshot!
Making a screenshot now.
But to clarify:
You have the Victoria 3.0 BASE? or the Victoria Base, as well as the head and body morph pack from Daz?
In other words, these nice preview pictures are for "nothing" and you have to change e.g. the face expression via the parameter dial?!? In this case, it is the unconvient truth for me...
Another question. If I buy e.g. a character (face) for the V3, is it the same problem with this REM and INJ or is it possible that the face change automatically?
Attached Link: http://www.daz3d.com/i.x/shop/itemdetails/-/?item=3008
Ok, do you have the Add-on V3 Morphs for Head and Body? Regardless of anything, the INJ or REM poses will not work without them.Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Quote - In other words, these nice preview pictures are for "nothing" and you have to change e.g. the face expression via the parameter dial?!? In this case, it is the unconvient truth for me...
If you buy or download a free character face with INJ poses, you NEED the V3 head morph for those INJections to work. You can buy just the head morph, but you'll eventually need the full pack (head and body) as I'm sure you'll want to transform your V3 into your own character. Same goes if you brought someones body morph...you'll need the body pack from Daz.
Quote - JenX, no I don't have these Add-On's of V3. That means, I should buy them otherwise it won't work. Is this correct? If yes, I will have to buy it...
Yes, you need them for most INJ/REM poses to work. Some creators make their own morphs with other packages and/or magnets, but those are most often found in for-pay packages, and not in the freebies. Although, there are some exceptions ;)
into a fruit salad.
Hi,
who can explain me what these two files ending in REM and INJ stand for? I have seen this kind of files in a package which I bought last week for my Poser 6 software. Now, I am not sure how important these kind of files are.
Thanks for all answers!!!
Peter
