Sat, Jan 25, 6:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Special colors in the material room
  • 1
  • 2
sirenia ( ) posted Sun, 04 November 2007 at 9:13 AM · edited Sat, 25 January 2025 at 5:58 PM
Hi all, Two questions this time for y'all :rolleyes: 1: Is it possible to create for example, a gradient color shift to hair that uses an image as a texture ? I know how to do it via Photoshop but i would like to know if it can be done in the Poser Material Room. 2: Also, can i change a hair color (or a cloth color for that matter) directly in Poser that also uses an image for its texture ? I guess this would be a 'node' thingy :sneaky: Thanks Wim
Society failed to tolerate me...
... and i have failed to tolerate society
pjz99 ( ) posted Sun, 04 November 2007 at 9:22 AM
Changing color uniformly is pretty easy:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2927631&ebot_calc_page#message_2927631
Changing color across a gradient is a little harder, I don't have an example at my fingertips, but might be able to throw something together in a few minutes.
My Freebies
SamTherapy ( ) posted Sun, 04 November 2007 at 9:28 AM
You can use the Color_Ramp node for the gradient, with the U or V variable node to drive it.  In fact, you can drive the Color_Ramp node with a lot of different things to get some completely barking mad effects. :)
sirenia ( ) posted Sun, 04 November 2007 at 9:51 AM
Hey thanks pjz99, i read the thread you gave and indeed, changing colors is fairly easy ! SamTherapy, could you maybe show me some screenshots please :blushing: then i would understand it a bit better i think.
SamTherapy ( ) posted Sun, 04 November 2007 at 10:02 AM
Quote - Hey thanks pjz99, i read the thread you gave and indeed, changing colors is fairly easy ! SamTherapy, could you maybe show me some screenshots please :blushing: then i would understand it a bit better i think.
Give me a few minutes and I'll post something up.
SamTherapy ( ) posted Sun, 04 November 2007 at 10:16 AM
I'm waiting for an example to render at the moment but I can tell you right now that it looks absolute bobbins.  The idea will work effectively if the hair you're using has one flat texture layout.  Otherwise, you're going to have to play around masking bits out, changing parameters here and there.  Probably easier to make or adapt an existing texture map.
I'll post the pics in a while, just for the sake of reference.
SamTherapy ( ) posted Sun, 04 November 2007 at 11:05 AM
This is the Material Room setup.
SamTherapy ( ) posted Sun, 04 November 2007 at 11:06 AM
And this is the render.
sirenia ( ) posted Sun, 04 November 2007 at 11:20 AM
Ooh thanks Sam ! Oh what fun it is in the Material Room now that i learn how to change things 🆒 Off to play with it now :tt2: Sam, is there any way to edit the gradient (change the direction of it) for example, let it change from left to right or maybe from the center to the edges ? Or is it only from top to bottom as it is on your screenshot ?
SamTherapy ( ) posted Sun, 04 November 2007 at 3:39 PM
Yes, you use the u_Texture_Coordinate for a left to right gradient.  You can also connect other math nodes and variables in there to give radial gradients or lava lamp effects.
A good source of ideas and useful stuff in its own right is a pack of free shaders posted by Ajax, which you should be able to find in Freestuff.
bagginsbill ( ) posted Mon, 05 November 2007 at 8:47 AM
> Quote - is there any way to edit the gradient (change the direction of it) for example, let it change from left to right or maybe from the center to the edges ? Or is it only from top to bottom as it is on your screenshot ?
Yes
bagginsbill ( ) posted Mon, 05 November 2007 at 8:53 AM
Adjust the transition.
bagginsbill ( ) posted Mon, 05 November 2007 at 8:56 AM
Same tricks work for ColorRamp. The only difference between Blender and ColorRamp is how many colors in your gradient - 2 versus 4.
bagginsbill ( ) posted Mon, 05 November 2007 at 9:00 AM
If we take advantage of the equation for a circle:
r = sqrt(x * x + y * y)
We can get circular gradients.
For x we use 2U - 1.
For y we use 2V - 1.
The Sqrt node shows the circular gradient. We then plug that into Blender or ColorRamp. Again, we can use Bias to accelerate or retard the gradient in r.
bagginsbill ( ) posted Mon, 05 November 2007 at 9:02 AM
The Subtract nodes (closest to U and V) are actually controlling the center of the circular gradient.
bagginsbill ( ) posted Mon, 05 November 2007 at 9:04 AM
The input multiplier on the ColorRamp or color Blender controls the overall rate of the gradient change. Using 2 instead of 1 doubles the rate of change. Using .7 reduces the rate of change by 30%.
bagginsbill ( ) posted Mon, 05 November 2007 at 9:06 AM
The ratio of the values in the add of x * x + y * y can be altered. (Math_Functions_8 in my shader.)
 Here I've used 3 * x * x + y * y. This gives us an ellipse instead of a circle.
bagginsbill ( ) posted Mon, 05 November 2007 at 9:08 AM
Instead of x squared plus y squared, try higher powers.
Here I've raised them to the 4th power instead. The gradient becomes more square.
Fascinating, eh?!?
bagginsbill ( ) posted Mon, 05 November 2007 at 9:12 AM
Once you understand that the gradient is a function which can be further manipulated by other functions, the possibilities are endless.
SamTherapy ( ) posted Mon, 05 November 2007 at 9:20 AM
Nice one, BB!
bagginsbill ( ) posted Mon, 05 November 2007 at 9:23 AM
The various noise nodes, such as Fractal_Sum, can be inserted to perturb either or both of the x and y dimensions. The resulting patterns can be quite interesting.
Indoda ( ) posted Mon, 05 November 2007 at 9:49 AM
Great visual examples, thank you so much
The important thing is not to stop questioning.
- Albert Einstein
Indoda
sirenia ( ) posted Mon, 05 November 2007 at 12:42 PM
Wow BB, thanks alot for all the examples ! This is gonna keep me busy next weekend, i would never have guessed that there was so much control power in the Material Room :-) Thanks all for showing me how to do this 👍 Wim
bagginsbill ( ) posted Mon, 05 November 2007 at 2:37 PM
Glad you like it. It's actually quite incredible what you can make with these nodes and the U/V coordinates.
For example, the pattern of fish scales in my avatar is done entirely with nodes - no image map was used.
Here's the full size image:
Or check out these bricks - all nodes:
Making patterns out of pure math on U and V is kind of my specialty. Check out this Glenn Plaid cloth pattern - all nodes - no images.
SSAfam1 ( ) posted Mon, 05 November 2007 at 3:01 PM
Any chance the nodes can make velour material for a sweatsuit? In POSER 6?
bagginsbill ( ) posted Tue, 06 November 2007 at 11:47 AM
Quote - Any chance the nodes can make velour material for a sweatsuit? In POSER 6?
I've tried a couple times without doing better than others have. There are some free velvet materials here and also at RDNA that are ok.
Velour and velvet shaders that others have done are similar to real velour in the same way that a box is more similar to an SUV than a sphere - directionally correct, but lacking accurate details. Most of the shaders I've seen end up looking more like satin, or more like terry cloth. I don't fully understand the physics of velour well enough to produce great results yet. I spent 3 hours on it this morning and failed.
bagginsbill ( ) posted Tue, 06 November 2007 at 1:19 PM
file_392715.txt
Well well. I started over, discarding the Velvet node and the bump map. Working from scratch using Edge_Blends and Blenders, this is what I came up with.
I've attached the Poser material file - save it as Velvet.mt5, removing the .txt at the end. I had to add that to be able to upload to this forum.
To change the colors, go into the material and find the Simple_Color node. Put any color you want in there.
I'll show the render next.
bagginsbill ( ) posted Tue, 06 November 2007 at 1:20 PM
Here are two colors using that shader.
bagginsbill ( ) posted Tue, 06 November 2007 at 1:25 PM
Two more colors.
pjz99 ( ) posted Tue, 06 November 2007 at 1:29 PM
That really looks great Bill.  Could you do me a favor (probably others as well) and also post the material file for the stuff you're doing with gradients above?  I was trying to reproduce it and didn't quite get it, I'm interested to take a close look at how you did it without my fat-fingering it and introducing some wrong config.
My Freebies
bagginsbill ( ) posted Tue, 06 November 2007 at 1:42 PM
Heheh. You think I saved those? I typed them in - took screen shots - and deleted them.
There's nothing difficult about making them from the screen shots. Anything that looks white is white. The numbers are all easy to read, I think. Each example builds on the previous so you don't actually have that much to type in.
Give it a shot.
SSAfam1 ( ) posted Tue, 06 November 2007 at 1:47 PM
Quote - Well well. I started over, discarding the Velvet node and the bump map. Working from scratch using Edge_Blends and Blenders, this is what I came up with.
I LOVE YOU!!!!!
bagginsbill ( ) posted Tue, 06 November 2007 at 1:54 PM
Ooooh - velour undies :)
SSAfam1 ( ) posted Tue, 06 November 2007 at 1:59 PM
I'm going to apply this material to some sweats I have and post them. :)
Thanks!
SSAfam1 ( ) posted Wed, 07 November 2007 at 11:23 AM · edited Wed, 07 November 2007 at 11:26 AM
Been playing around. I'm finding the colors work best when dark due to the noise. I tried a light pink and it came out dark...although natural looking.
CLICK TO ENLARGE
SSAfam1 ( ) posted Wed, 07 November 2007 at 11:24 AM
result...
SSAfam1 ( ) posted Wed, 07 November 2007 at 11:24 AM · edited Wed, 07 November 2007 at 11:27 AM
played around some more. The color I was shooting for is the border color of the image. Not so natural looking.
ice-boy ( ) posted Sun, 31 May 2009 at 1:36 PM · edited Sun, 31 May 2009 at 1:37 PM
bagginsbill is the velvet node bad or was it because we didnt gave gamma correction?
bagginsbill ( ) posted Sun, 31 May 2009 at 4:07 PM · edited Sun, 31 May 2009 at 4:07 PM
I don't know if the velvet node is bad or not. Like so many other nodes, I cannot find the formula - what it actually is doing. Since I know what I want to do, but I don't know what it is doing, I don't use it. Given the choice, I do what I want mathematically, not guessing. I have done much experimenting with nodes, but any that are specialized with no explanation are essentially useless to me. I'm not going to work out the millions of parameter values and how they influence each other if I can build what I want in 20 minutes from math nodes.
ice-boy ( ) posted Sun, 31 May 2009 at 4:47 PM
thanks.
i tryed the one that you posted here in 2007.looks very good. but its not GC. how would you transform this to GC?
bagginsbill ( ) posted Sun, 31 May 2009 at 6:19 PM · edited Sun, 31 May 2009 at 6:20 PM
file_432009.txt
Velvet with GC. All you do is add the anti-GC and GC nodes, add a Diffuse, and move the connections to the new Diffuse node from the old PoserSurface. Since this one has no specular at all, it is was very easy.
I just did this in Poser Pro, so the version number is high. People without Pro will get  warning - ignore that, or you can fix it by editing the material file in a text editor - change the version to 5.
Latexluv ( ) posted Mon, 01 June 2009 at 2:22 AM
Thanks so much bb! I just loaded it up into my Poser. Okay, so I have a question. I try to follow the threads, but  I guess I have missed where this was discussed. If I were to add GC to a hair texture, where would I begin attaching nodes for the hair textures into the GC nodes?
Weapons of choice:
bagginsbill ( ) posted Mon, 01 June 2009 at 2:37 AM
Here is a screen shot of a decent GC shader for most things.
http://www.renderosity.com/mod/forumpro/media/folder_9/file_423332.jpg
This shader implements the correct way to do GC and also to trade off specular versus diffuse reflections. Other than that, it's your basic diffuse and specular effect.
It uses a Blinn node for specular, which is much more realistic for most things than a Specular node is. The Specular node is what is built into the Poser Surface - what most people have used. You can use the Specular node instead of the Blinn node if you like, to make an existing hsader more like what it already is.
If a shader has some other specular node, such as Glossy or Anisotropic, it would probably be plugged into Alternate_Specular. Unplug it from there and put it where this Blinn goes.
If you have transparency, bump, or displacement there's no need to change those parts. GC only deals with the generated colors.
bagginsbill ( ) posted Mon, 01 June 2009 at 2:41 AM
In that shader, I showed a color map from a texture set. This is the color of the material. It does not have to be a map. Instead, you could plug in nodes to make the colors, so if you're converting a procedural texture, that's where you'd plug in the colors. Most shaders, even procedural, have the important color generating nodes going into Diffuse_Color. Whatever they are, just plug them in where you see the color map.
If you're converting a shader that uses ambient or translucence, it's probably a bad hacked-up I-don't-know-why-I-did-that-I-just-thought-it-looked-good type of shader and you should not convert it. :)
Latexluv ( ) posted Mon, 01 June 2009 at 2:41 AM
Thank you! I'm copying and pasting into a Word document for my Node files.
Weapons of choice:
Latexluv ( ) posted Mon, 01 June 2009 at 2:47 AM · edited Mon, 01 June 2009 at 2:48 AM
What are your thoughts on using material based AO on a hair texture? I've plugged in AO to a hair texture a few times. Sometimes it looked good on final render, sometimes it seemed to only make for a longer render.
Weapons of choice:
ice-boy ( ) posted Mon, 01 June 2009 at 4:59 AM
Quote - Here is a screen shot of a decent GC shader for most things.
why is the specular subtracted and plugged in the diffuse?
bagginsbill ( ) posted Mon, 01 June 2009 at 3:06 PM
For conservation of energy. Because it looks better.
Let's say using some incredible physics monitoring equipment you watch 1000 photos arrive at a surface.
Let's say 300 of them (30%) bounce of the air-surface boundary, making a specular reflection. How many are left to make a diffuse reflection or sub-surface scattering? Not 1000 any more, but 700. The other 300 left already.
So - where there is more specular there must be less diffuse. QED.
There is also the hyper-color problem.
Consider a bright red plastic, RGB(255, 0, 0). Diffuse reflection from a 100% light would produce RGB(255, 0, 0). But what if you are looking at a spot that produces a specular reflection of RGB(50, 50, 50)? Then the sum is RGB(305, 50, 50) which is impossible to render. What happens is the red gets clipped so the actual rendered color is RGB(255, 50, 50).
Now what happens as you look at the surface falling away from the hot spot? The diffuse and specular are decreasing with the changing angle. But! Because of the hyper-color clipping, the red component is still 255, while the blue and green are dropping 40, 30, 20, etc. This looks strange, and produced a glowing halo around the hot spot.
I will render a demonstration. Give me a few minutes.
ice-boy ( ) posted Mon, 01 June 2009 at 3:23 PM
interesting. but where could we now connect the AO?
bagginsbill ( ) posted Mon, 01 June 2009 at 3:30 PM
Here is the demo. Two big spheres, two small spheres. Each has a skin tone in diffuse color. Each has a white Blinn node for specular. On the left, the subtraction is not done, on the right it is.
Notice the yellow ring around the highlight on the left?
To connect AO, add a Math:Mul node. Connect it to Diffuse_Value. Connect AO and the 1 - specular to the Mul node.
bagginsbill ( ) posted Mon, 01 June 2009 at 3:32 PM
Previous was a single infinite light at 100%. Here is the infinite at 70%. So it is not just when you are dealing with hypercolors - it is also at normal illumination levels. In fact, in some cases it is even more obvious.
  • 1
  • 2
