Have you opened up CrossDresser to see if Terai Yuki has a yes by her name?
I've noticed that when I install, I need to actually open the CrossDresser folder up after I browse to it.
I use both programs. CrossDresser to convert from figure to figure and WW to then convert to the morphed figure. For me, this combination gets the best results.
Quote - Have you opened up CrossDresser to see if Terai Yuki has a yes by her name?
I've noticed that when I install, I need to actually open the CrossDresser folder up after I browse to it.I use both programs. CrossDresser to convert from figure to figure and WW to then convert to the morphed figure. For me, this combination gets the best results.
It finally worked for me thanks I had to exit out of everything.
When you said WW to convert to the morphed figure, What do you mean? is it because CRXD doesn't support morphs so WW will make the clothes fit the morph figure? Such as larger legs, abs or breasts?
Don't let failures get to your heart, and also do not let success get to your head.
With WW:
You 1st load the original Figure with the XD converted clothing?
Then you load the Morphed Figure and use WW to convert to the Morphed Figure?
Sounds simple enough, I haven't tried that yet.
Tks
DR
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
Attached Link: Example
Mariner, it's a lot simpler, and faster, that just using either program alone.Here's an example. 5 items of clothing (Aiko, V4, V3) converted to David and then WW' d to fit a morphed David. Time needed--15 minutes.
I do it it batches now. Convert all the items I want first. Then have WW read all of them. Finally have WW convert them all.
Quote - Mariner, it's a lot simpler, and faster, that just using either program alone.
Ouch WW cost a bit more, I could really use it right now, because some poses gives me a poke through.
Not to mention the suit that im using requires me to set it on high.
Using Cross Dresser at a very high settings requires a strong computer I am guessing because it took me 45 minutes to convert it on the high setting, also if I do anything else the program freezes, So i have to leave the computer alone and do absolutely nothing.
If you're transfering from one character to another, in most cases, that won't work - the morph delta informatino isnt' pertient across figures. In the case of bodyhandles and non-standard parts, though, it can be sometimes useful to keep the morphs that are there. WW can do this, and PhilC has a tutorial on his site to describe the process.
JonTheCelt
I heard a rumor that Wardrobe Wizard is being updated with new features. I read a couple of posts where PhilC was asking for feature request and another where he is asking for testers but cagily refrains from saying what it is that is being tested. He just asks that responders email him a list of the scripts they own.
A most requested feature was the ability to have FMB's automatically built in. He appeared to be responsive. I'd lay money that he is coming up with something spectacular.
Quote - I heard a rumor that Wardrobe Wizard is being updated with new features. I read a couple of posts where PhilC was asking for feature request and another where he is asking for testers but cagily refrains from saying what it is that is being tested. He just asks that responders email him a list of the scripts they own.
FMB? What is that?
Quote - The dials in the body. The ones you turn to adjust all the body parts at once. V4 has a gazilion of them.
That would be really nifty indeed, V4 has some really nice outfits that I want to put on Terai Yuki and Maya Doll Since they are the 2 with the least support when compared to V4 and A3
I just got the license for Terai Yuki and Tried to install the license but it doesn't seem to be installing, It says install but I don't see the license being installed.
Anyone else having the same problem?
