Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
Short of modelling one yourself or dropping an existing model into a modellling app, I can't think of anything. I'm guessing you're looking for something like the living quarters of Discovery in 2001.
Stonemason will probably have something you can use over at Daz, short of that you are going to have to start pushing polygons around I think
My Freebies
Buy stuff on RedBubble
Try this one..
Corridor Construction Kit
http://www.vanishingpoint.biz/productdetail.asp?Productid=320
Attached Link: Tycho Station
sort of like Poseworks this is a LARGE stationYou might as well PAY attention, because you can't afford FREE speech
The lower limit on size is connected to the acceleration differences between feet and head. but it would need to be pretty big. What I'd do is make the origin of the object at the centre, place and pose each figure in the default location, parent to the scenery, and rotate the whole. I'm not explaining it well, but there is your local vertical changing with position.
a torus would do it; problem is lighting the megilla..I've discovered that lighting enclosed objects is difficult, because it cuts off the basic 3 lights...what I don't know about Poser lighting would fill a Geep University....;) sounds like the space station in 2001, still...;) there was a site (I think) called strafe something, had almost every 2001 model there was. Try googlin' that...
Hi all. I am working on an image set on a space station, but they don’t have grav plates and use the rotation of the station to give them a feeling of gravity. here’s my problem anyone know how I can bend a corridor floor and walls?. To give you some idea of the look I am going for. I have Frontier Station.SFCS. if that’s any help. If you can help thanks ahead of time. If not thanks for looking.
