It really depends on a couple of factors.
maybe the biggest factor is the complexity of the cloth, how many polygons are involved in collision calculations; if you are doing a animation with only a simple skirt for instance, you have a relatively low poly object only colliding with the hip & upper leg area of your figure. quick.
A more complex cloth which collides with everything but the head and feet is going to require big calculations for every frame, which is going to take forever.
I guess, as with everything else, it would help if you more clearly defined what exactly you are trying to do.
Let it run overnight, and see how far it gets.
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
i tried using dynammic clothes alittle but, Just doing a 30 frame anim...the calculation takes unbearably long. Am i doing something wrong, or is it slow to everyone? i use poser 6 on a mac
