Tue, Feb 18, 1:20 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: Can You Convert Poser PC Files To Poser Mac OS X Files?
Isyl ( ) posted Mon, 12 November 2007 at 8:24 PM · edited Thu, 06 February 2025 at 3:05 AM
How do you convert Poser PC files to work in Poser on Mac OS X 10.3+? Is there a good but free or inexpensive app that will easily do this? Is this possible to do? I'm a total Poser newbie, I just got Poser 7. Any help and suggestions would be sooo greatly appreciated!! Thanks all.
Penguinisto ( ) posted Mon, 12 November 2007 at 8:34 PM
It should load just fine in OSX normally... there's a group of apps out and about though if you need to convert the odd image or pathing munge-up. Check the Macintosh forum for a listing (I'd just list them here, but I'm nowhere near my own Mac where I keep the list).
/P
kuroyume0161 ( ) posted Mon, 12 November 2007 at 8:49 PM · edited Mon, 12 November 2007 at 8:49 PM
There is no difference between the files with respect to Poser.  The hard part is installing content into the Runtime without overwriting existing folders on MacOS (as it replaces folder contents whereas Windows merges folder contents).  DittoGUI is good for this - Daz3D has MacOS installers otherwise.
I've literally copied (carefully with the caveat mentioned) Runtimes on my Windows system to my Mac system and everything works.  There is no real need for conversion.
Now, there are some issues with Poser 4/ProPack and earlier in regards to Windows and MacOS - but using Poser 7 in MacOSX you should not worry about this.
 -- Bjarne Stroustrup
PhilC ( ) posted Tue, 13 November 2007 at 3:05 AM
Here is a free utility that takes away the pain of installing zips into Poser 7 on a Mac.
http://www.philc.net/unzip.htm
kuroyume0161 ( ) posted Tue, 13 November 2007 at 10:51 AM
Leave it to Phil to have already created a Poser Python utility to assist in the process... :D
PhilC ( ) posted Tue, 13 November 2007 at 10:59 AM
heh :)
I have to confess it was self interest. I only use a Mac to test out my scripts on. It was driving me nuts having to drill down every directory and copy files over. So since I have a policy of working hard to be lazy I created the script.
gagnonrich ( ) posted Tue, 13 November 2007 at 1:33 PM
Out of curiosity, is there anything that does the reverse?--Going from Mac to PC.  I remember getting a bad Freak .exe file on one of the ComputerArts CDs and the Mac file was supposed to be okay.
My visual indexes of Poser content are at http://www.sharecg.com/pf/rgagnon
Ghostofmacbeth ( ) posted Tue, 13 November 2007 at 1:42 PM
From what I understand the only way to do that was with an older mac that can run classic (and you have to have the Mac).
Ghostofmacbeth ( ) posted Tue, 13 November 2007 at 1:43 PM
At least that I knew of.
