Mon, Dec 2, 7:25 PM CST
Subject: Change the Wireframe color
thadrax ( ) posted Mon, 04 June 2001 at 3:24 PM ยท edited Sat, 30 November 2024 at 10:07 PM
Attached Link: Tha DraX
It may be a lame question, but i can't figure it out. How do i change the color of the wireframe in the wireframe display? Please help me. Thanx Tha DraX
LatexBard ( ) posted Mon, 04 June 2001 at 3:30 PM
Change the foreground color.
thadrax ( ) posted Mon, 04 June 2001 at 3:32 PM
Attached Link: http://thadrax.8k.com
I did that but it still stays pink, for some reason.
LatexBard ( ) posted Mon, 04 June 2001 at 3:43 PM
Just double checked.... Here is what I did... Set Document display to wireframe, Figure and Element to use document settings. Used Display|Foreground Color to chose about 6 differant colors and the it changed to each new one. You may have some display setting changed so it does not display it.
thadrax ( ) posted Mon, 04 June 2001 at 3:58 PM
Does it matter if i got 'Depth Cued' on? and is there some way to reset all the settings?
Don ( ) posted Tue, 05 June 2001 at 12:07 AM
Attached Link: http://Cyber-Fyber.bbay.com
1. Color your Wireframe figure or object white with black reflection. 2. Set the background color to a fairly dark neutral grey. 3. Experiment with changing light settings, using colorful lights. 4. Tweak your background and Ground colors to go with your final light selection. 5. Further- you can tweak reflection color, trnsparencies, etc. for more effects. The way to do it is with lights. Depth Cue may wash out wireframe images. DL my Neon Lights for Poser Nights. Try these on your wireframe models and see what you get. -3Don
