Sun, Feb 2, 3:45 PM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: Vector pen tool (Illustrator / Photoshop)
stephenbuck415 ( ) posted Thu, 15 November 2007 at 3:29 AM · edited Thu, 16 January 2025 at 2:30 AM
I'm using CS3 Extended.
I need to create a vector line with the pen tool.  Easy enough but I want the stroke width to vary.
At beginning point "A" I want it to begin as an actual point, like the head of a pin.  The approach towards end point "B" should grow to a greater width (10 pts for example) and then back to a single point like the head of a pin when it reaches point "B".
I can create this effect using two joined strokes with a fill but I would prefer to make this effect with a single stroke.
Is that possible with a single stroke?
RandC ( ) posted Thu, 15 November 2007 at 7:28 AM
In illustrator that would be easy, just draw the shape using the pen tool and drag to the brush pallet to create a new brush, that way you can add the new brush to any stroke and have the same effect....soory don't know how to do it in Photoshop.
stephenbuck415 ( ) posted Thu, 15 November 2007 at 9:02 PM
Thank you.
retrocity ( ) posted Thu, 15 November 2007 at 9:52 PM
hummm. interesting question. I usually use Illustrator for all my vector path stuff. only use the pen tool in PS when it's a simple "quick-and-dirty" request. not sure "how" you would go about it in PS.
my suggestion is to create a closed shape with a colour fill, but you've already done that...
let's see if anyone has a solution.
retrocity
thundering1 ( ) posted Fri, 16 November 2007 at 2:10 PM
Is THIS what you had in mind? If not, lemme know and I'll try to come up with something else. Good luck - hope this helps- -Lew ;-)
thundering1 ( ) posted Fri, 16 November 2007 at 2:12 PM
JUust reread it again - based on the abov image, bend the handles (Alt key, grab a handle and move) of the BOTTOM point as well. You can move the handles around to give it any shape you want - including a wavy form that goes wide in the middle and back to a pointat both ends.
Good luck-
-Lew ;-)
stephenbuck415 ( ) posted Fri, 16 November 2007 at 2:53 PM
Hmmm.  Helpful but not quite what I'm seeking.
I'll try to rephrase my original question:
I can draw a line in Anime Studio Pro.  In the Fill tool panel is a tool called "Line Width (W)".
I can select that tool, place it over one point of the line/path just drawn, and vary the width of that point.
That's what I'm trying to do.
Take a look at Supergirls eye lashes:
http://www.renderosity.com/mod/gallery/index.php?image_id=1359637&member
They are wide at the base at the eye lid and extend to a sharp point.
I can create that effect in Anime Studio Pro with the Line Width tool using only a single stroke.
Does Adobe Illustrator have a similar tool?
thundering1 ( ) posted Fri, 16 November 2007 at 3:23 PM
AAAAhhhhhh!
An actual "stroke"... But Vector...
Bummer, I know how to do it bitmap (custom brushes in PS and Painter) but not in vector tools with Illustrator os PS...
I HAVE seen a tut on how someone made a varied stroke using a path in PS, but that was using the path as a guide and a regular brush for the width.
God, the only way I can think to do it vector would be to actually draw out the outlines of the "black" shapes you wanna fill - it would be easy to do, just more time consuming.
I guess I'll be waiting to see if someone comes up with a solution to this one myself.
-Lew ;-)
karosnikov ( ) posted Tue, 20 November 2007 at 7:58 AM
turn the brush dynamics on... i think the bruh size can be set to fade from 100% size to 0% size to scale.. a simple two point line , last time i tried to do this - started thin, thickend up in the middle and thinned toward the end.  it may be possible to achieve the effect you want  by adjucting a frew settings..  oh   "stroke  path" is  under  one of the menu's.. tired sleepy...
Zzzzzzz
"I'm in your image, lol, pushing it's pixels"
