Wed, Jan 22, 9:41 PM CST
Subject: Bryce Landscape tips tutorial
dhama ( ) posted Fri, 23 November 2007 at 3:18 AM · edited Wed, 22 January 2025 at 9:12 PM
I hope this is of help to others wishing to create more realistic looking landscapes.
This is not a step by step guide, but a list of tips. One could then just use the tip relevent to their scene, although I think most of them will be relevent.
*1. Landscape scenery using Bryce can be difficult to achieve without at least some outside help, even if it's just to change the ambience level.... but to the other extent using objects created on other apps is not only useful, but helps the scene look more realistic.
  1. Any real live scene has a certain heaviness to it, everything lays correctly and nothing lies stiff or unrelaxed. This can be overlooked when producing a scene.
  2. Try to make your scene look more uneven too, if there are too many objects like trees for instance standing straight, the scene looks unbeleivable. But if you slightly angle trees in different directions they look more natural.
  3. The foreground part of the scene should take up maybe 80% of the building time since it needs to have more detail, take time to perfect this before thinking about  a background.
  4. Use more than one terrain. You can copy and alter terrain and texture with different Mats to make the ground look less uniform.
6.  Give your scene a purpose, give the eye something to do. Add a main object that will lead the viewer to another part of the scene.
  1. Use 2D planes with images, for say, skies, or just clouds, or any elements that needs to have a more realistic edge to them.
  2. Add in a splash of alternate colour to your scene, like a single flower using a different coloyr from the overal them colour.
  3. If you can, use an art app like Photoshop, Gimp, Painter etc. to add other effects that can make an ok scene look more spectacular. Ambience, Colour boost, Monochrome (this works well in some cases). And if you feel adventurous, painting in more detail. This can be useful if you want to touch up an area that looks less realistic, like a wood texture. You can even use photographs, or part of them at least to super impose over a texture using 'overlay' if your art app has this function.
  4. Last of all, take your time. If you're not happy with a scene, start again. I get through many a scene before i'm happy with one.* **Patience is the final frontier.
    Hope this helps.
If I have any more thoughts on this, i'll post it here. If anyone else would like to add to this, please do, but keep it in the context of landscapes.
bobbystahr ( ) posted Fri, 23 November 2007 at 10:37 AM
Good post...if enough members request it, I'll make this a sticky as it'd be quite good reading for newbies.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
dhama ( ) posted Sat, 24 November 2007 at 12:13 PM
Thanks bobbystahr but it seems nobody is interested. Can see i'm just wasting my time and efforts here. I was going to follow up with a step by step guide, but theres obviously no point.
It seems you need to be a member of some special group for anyone to take notice of you. How sad :sad:
MegaJax ( ) posted Sat, 24 November 2007 at 1:15 PM
I'm interested.....
I need all the help,  hints and tips I can get. I am still only in the play mode at the moment, discovering what the basic stuff is.
bobbystahr ( ) posted Sat, 24 November 2007 at 5:43 PM
See dhama...we gota let the interested see this post for a bit before hasty decisions are made. I for one am just coming back to Bryce5 having been off in other cyber pursuits and only just got back onboard with the free ver5. and found your tips worth bookmarking. You brought up some valid point in the first post so I would say, continue and keep posting them here and they will show up on a site search as well as on the main Bryce Forum Menu so may get increased hits that way. In any case if you've helped even one member you've done a service that many members never will.. ...
I see a sound
AnnieD ( ) posted Sat, 24 November 2007 at 9:24 PM
I agree with megjax..I need all the practical help I can get too..
And it is a holiday weekend...lots of ppl are gone.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
Incarnadine ( ) posted Sun, 25 November 2007 at 9:04 AM · edited Sun, 25 November 2007 at 9:05 AM
I always look at tut's and guides. Even if I am already aware of a lot of your points, a refresher is always good and a different perspective always brings new ideas or inspirations. Even though I post mostly in the C4D gallery, I still use bryce a bunch!
dhama ( ) posted Sun, 25 November 2007 at 9:34 AM
Sorry, but it's just that i'm used to forums where some people at least reply if they view, and when over 50 people view and not reply, it seems like no one is interested.
I will continue with my step by step guide tutorial for landscapes that i'm currently workibing on. Might take a little while to complete.
Incarnadine ( ) posted Sun, 25 November 2007 at 10:13 AM
With the year end approaching at work and a stack of aircraft and projects to deliver, I don't get in here as often or as long as I would like - more hit and run at best. please continue, as I stated fresh perspectives are always welcomed (from my point of view)!
deadwarrior ( ) posted Sun, 25 November 2007 at 2:28 PM
dhama, please continue with your terrain tuts. I'm interested and I'm sure more Brycers are interested than you suspect.
Maybe they're shy about responding, but I'm not. I always like to learn new tips and techniques.
So please work on that step-by-step guide.
I know I'll read, print it out and use it, and I'm sure others will too.
"Welcome back my friends to the show that never ends, Come Inside, Come Inside."
Brain Salad Surgery"
Emerson, Lake and Palmer
MegaJax ( ) posted Sun, 25 November 2007 at 5:49 PM
dhama, don't forget that a lot of newbies that use these site are very shy and lacking in confidence. I have been a member here for a few years now (I used a different name when I first joind around 5 and half years ago) but it took me ages to even post comments on images in the galleries, and I only started posting in the forums a month or so ago.
So for all those newbies that are just viewing our wonderful community at the moment Please continue your tips, tricks and tutorials
Ang25 ( ) posted Sun, 25 November 2007 at 8:13 PM
Holiday, just got a few minutes to catch up on the posts and yes, this is very good information! Sorry I wasn't one of the first 50 viewers or I would have commented. I have trouble with #6, I never seem to find a good focal point when I do a landscape. I do #3, I love to tilt my trees so that they bend in different directions.
Anyhow, these are good steps and I can certainly use this information to improve myself.
Thanks
dhama ( ) posted Mon, 26 November 2007 at 4:49 PM
Of course I will continue, now that there is interest. :-)
Quote - I have trouble with #6, I never seem to find a good focal point when I do a landscape.
Take this test then. Type in 'Landscape' in any search engine that has a choice for images.... like Altavista for instance. As the thumbnails are displayed, look at each one in turn (for only as long as you wish to continue) and write down the first impression of each of them. The impression should be the thing or object that the eye is drawn to first.
Now, when you think about your own landscapes, remember back to the test and what your impressions were, wether they were positive or negative. This should give you some insight into what works and what doesn't.
Why does this work? because it is far easier to see incorrect elements in a landscape when it's by someone else, than if it were your own. It's true; try it. :)
RodsArt ( ) posted Mon, 26 November 2007 at 7:25 PM
Great list for Landscape comp.  I just dropped a link to "rstar" for a great landscape comp multi page that supports lots of what you've covered here.
Keep it comin!!
___
Ockham's razor- It's that simple
rubidium ( ) posted Tue, 27 November 2007 at 6:17 AM
Hello,
I think that this is a very useful post. However, I have a question regarding point 3...
*3. Try to make your scene look more uneven too, if there are too many objects like trees for instance standing straight, the scene looks unbeleivable. But if you slightly angle trees in different directions they look more natural.
*Is it possible to modify the angle of the trunk? I thought that it is not possible in Bryce...
Best regards
Ramon
Incarnadine ( ) posted Tue, 27 November 2007 at 6:44 AM
All you have to do is go in and select a tree, rotate, size, stretch, etc. with the edit tools as you would like. Basically you just treat it like any other object. This gives you a more natural forest sense.
rubidium ( ) posted Tue, 27 November 2007 at 6:47 AM
OK. I'll try it. Thank you!
Ramon
rubidium ( ) posted Tue, 27 November 2007 at 3:29 PM · edited Tue, 27 November 2007 at 3:33 PM
I think that is what you meant... I have use the rotate tool... however, if the rotation angle is not small the result is unnatural... Thank you for your tips!
Ramon
Edit: I was not able to upload the picture...
ThunderStone ( ) posted Sat, 01 December 2007 at 8:14 AM · edited Sat, 01 December 2007 at 8:16 AM
Quote - Sorry, but it's just that i'm used to forums where some people at least reply if they view, and when over 50 people view and not reply, it seems like no one is interested.
Hey dhama, I just came in on the "rat's end" of the forum and just happened to read your very helpful tips on landscape. Don't give up. It takes time before someone who's looking for tips and guide into Bryce's misunderstood landscaping, will happened upon your thread. Soooo
My point is: I'm interested!!!
TS
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
FranOnTheEdge ( ) posted Sat, 01 December 2007 at 12:21 PM
I too am interested, but with deadlines on projects I only really have time to look though most of the forum - if I get a chance to get in here at all!
Replying to everything I'm interested in takes more time than I really have just now.
Weekend now so more time, well... a bit.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
dhama ( ) posted Sun, 02 December 2007 at 2:12 PM
I've just got a new system, so hopefully I can start the step by step tutorial.
