@martial...you do know you can get your Forum Moderator to go in and edit a post for you if you wish to correct something...give agiel an IM...I'm certain either he or Sarge will help in that regard
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Greetings all. Martial and I worked on a solution to resolve his issue.
This was the first issue and the only issue so far.
I verified that the sub-groups inside main groups on HIS machine only, were the issue by removing them.
Then we just ungouped the purchased model, then regrouped it again to give his system a new
saved model.
This solved the issue of the cranky importer.
Life goes on!
110% effort and counting.
