Attached Link: http://img.fotocommunity.com/photos/8698321.jpg
oh really? ;)no i wanna get some light effects when it shines through the crystak pyramid or as you see...the light around the glas
I admit I am nieve about version 6 so for that reason I hesitate to say dispersion and reflection don't work in version 6 but they don't unless that's been changed. making lenses (ie refraction) does work. I played with these extensively in earlier versions of Bryce so up to version 5.1 I know pretty much what I'm saying.
I can't get the picture link to work (error 403), so I can't see the example.
Bryce does reflections; but can't do reflectivity (bounce light). So you can't bounce luminosity directly; but you can show a reflection.
It can do surface refractions, but not volumetric. Index of Refraction is singular (no mapping for it, no dielectrics, etc.), and can't layer. So you can't do prismatic effects directly.
There is no photon mapping, so you can't do nephroidal caustics, just simple (and missing the reflective component).
You can do a fair simulation of diffuse inter-reflection and specular reflectance (color bleeds) via ambient channel + True Ambience; but it is not completely accurate, hard to set up, and is very render intensive.
Friends don't let friends use booleans.
(Quote) "...but can't do reflectivity (bounce light)..."(/Quote) yes, that's what I meant. Some really neat stuff can be done with mirrors,lenses and the right camera position though. (try putting the camera inside a lense or near a lense for example). I suspect alot of the above pict is faked ie the angles of incidence and coincidence are actually two beams of light rather than 1. although if you look closely you'll see some use of mirrors too.
remember when faking the angles of incidence(striking the mirror) and coincidence(bounce) should be equal normal to the plane of the mirror. That's part of Snell's law which applies even in refraction once the critical angle is reached. (I actually remember this from optical minerology but couldn't find a reference to this part in google.)
i wanna know how to make a reflection of a laser beam.
if the beam hits the mirror, it don´t reflects to another direction.
it still looks like it hits a wall.
thx anyway
