Thu, Feb 6, 6:50 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
Subject: V4 nolonger will nolonger load in P7
SoulTaker ( ) posted Sun, 02 December 2007 at 5:05 AM · edited Thu, 06 February 2025 at 6:39 AM
Ok up until now, I have not had any real problems. Up until now that is.
V4 will not load in poser7. That’s it that simple. The system just hangs, the little hour glass keeps turning over. But noV4.
She loads no problem in poser6. (V4 is sitting in a poser6 runtime & poser7 is linked to this)
But does not want to play in 7.
She loaded before. I have reinstalled her but to no avail
If anyone has any ideas or any help it would be most welcome.
MegaJax ( ) posted Sun, 02 December 2007 at 5:52 AM
is it V4 or V4.1 you are using? because V4.1 does not like being outside the main Poser 7 runtime where as the V4 should work from anywhere
RHaseltine ( ) posted Sun, 02 December 2007 at 8:54 AM
Copy Poser 6Runtimelibraries!DAZ to Poser 7Runtimelibraries!DAZ (or whatever your Poser folders are called) and try loading again. The only drawback to this is that you need to keep both instances of the !DAZ folder up-to-date if you add new sets that use ExP system (generally that would mean sets of morphs with a large number of morphs, not characters or clothing).
Acadia ( ) posted Sun, 02 December 2007 at 9:05 AM · edited Sun, 02 December 2007 at 9:15 AM
4.1 has to be installed in the main poser runtime.  However you can make a copy of the files and place them in any runtime you want.  Don't forget to run to .dos update file on your desktop.
wdupre ( ) posted Sun, 02 December 2007 at 1:04 PM
actually the V4.1 morph files dont really have to be installed in the main P7 Runtime, you can change the file search preference in Poser 7 to shallow and she should load just as well from an external runtime.
SoulTaker ( ) posted Sun, 02 December 2007 at 1:04 PM
THANKS ALL
I'm happy again
