Mon, Dec 2, 2:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 2:40 am)
Subject: Poser 7 very slow compared to Poser 6
azjazz ( ) posted Sat, 01 December 2007 at 1:08 PM · edited Mon, 02 December 2024 at 2:40 AM
Why is Poser 7 so much slower than Poser 6 on my dual-core PC? I thought Poser 7 handles multiple cores better?
For example, using (Poser 6 Hi Res Jessi + bikini top + bikini bottom + strand hair) immediately after program start, with no other changes:
  • Poser 6 render time: 2:30
  • Poser 7 render time: 6:45
I have an AMD64 X2 4400+ with 2 GB RAM.
I would have thought that Poser 7 would have been at least as fast as Poser 6, if not faster.
Darboshanski ( ) posted Sun, 02 December 2007 at 12:16 AM
For me poser 7 renders way faster than P6 and I run an AMD 64x2 3800. I had scenes that Poser 6 wouldn't even render but P7 did and much faster.
My Facebook Page
azjazz ( ) posted Mon, 03 December 2007 at 4:26 AM
Quote - For me poser 7 renders way faster than P6 and I run an AMD 64x2 3800. I had scenes that Poser 6 wouldn't even render but P7 did and much faster.
That's what I was hoping for, but I don't see it happening on my PC. Another thing I tried was bringing up the Windows Task Manager, and it looks like only one core is being used, since my CPU Load never got over 60% when rendering (Processor Affinty was set to CPU 0 and CPU 1).
Anybody have ideas on what's going on?
Dim_Reaper ( ) posted Mon, 03 December 2007 at 5:46 AM
I'm at work right now so I can't check the exact settings, but in Options there is a check box to "Render as separate processes" or something similar.  Also a slider for threads if I remember right.  Try changing these, restart Poser and try rendering again.
Sorry I can't be more detailed - been a while since I had to change these.  If I get home before you check back here then I'll post some more detailed instructions.
i7 5960X, 32GB RAM, GTX 1080Ti, GTX 980 Ti, Windows 10 Professional.  Running Daz Studio 4.11, Poser 11, Vue Inf 7, Photoshop CS4
azjazz ( ) posted Mon, 03 December 2007 at 8:11 AM
Quote - I'm at work right now so I can't check the exact settings, but in Options there is a check box to "Render as separate processes" or something similar.  Also a slider for threads if I remember right.  Try changing these, restart Poser and try rendering again.
Thanks! That did the trick - Render for my Hi-Res Jessi test is down to 1:53.
I'm assuming that the thread count should be the number of cores that I have, right? So, when I install my quad-core, I should set it for 4?
Dim_Reaper ( ) posted Mon, 03 December 2007 at 11:37 AM
Really glad to hear it is working for you now.    Nothing like the thrill of multiple cores tearing through a render :-)
As I understand it, you might get a further increase by changing the number of threads to 4 even on your current processor.  Whether you get an increase in speed depends on the memory in your system and the memory requirements of the scene.  When you get a slow day then it might be worth trying it with a scene to see if it makes a noticable improvement.
Info for when you upgrade:  I'm running a quad core with 2 Gig of RAM on Windows Vista.  I have the number of threads set to 4, but I've found that having the Separate Process box unchecked works best for me.
Just realised that I have the manual in PDF format here, so here's the relevant part on page 26:
Render Process Settings**
renders in a separate process on the CPU, and vice versa. This feature is disabled by
default. For more information on Rendering in a Separate Process, see
Technology” on page 352
***Separate Process: Checking the **Separate Process box enables running FireFly“FireFly.*****?
you can take advantage of multi-threaded rendering by setting the
Threads
dual-core system, you may see increased benefit from setting the number of threads to
four, rather than just two. However, if you have a single-processor and single-core
system, we recommend that you set the number of threads to one, as the increased
memory demand of running parallel threads may offset the performance benefits. For
more information on multi-threaded rendering, see
****Number of Threads: If you have a multi-processor and/or multi-core hardware system,**Number ofslider to a value greater than one. Even if your system is a dual-processor or“FireFly Technology” on page 352.******NOTE
EVEN WITH A MULTI-PROCESSOR OR MULTI-CORE SYSTEM, IF YOU ARE RENDERING A
HIGHLY DETAILED, MEMORY INTENSIVE SCENE YOU MAY FIND THAT YOU HAVE BETTER
RESULTS BY SCALING BACK THE NUMBER OF THREADS IN ORDER TO REDUCE MEMORY
OVERHEAD. WE RECOMMEND RENDERING YOUR SCENE WITH FOUR THREADS, AND IF YOU
ARE UNSATISFIED WITH THE PERFORMANCE RESULTS, OR IF THE RENDER FAILS TO
COMPLETE, THEN REDUCE THE NUMBER OF THREADS.
azjazz ( ) posted Mon, 03 December 2007 at 8:30 PM
**Dim_Reaper - Thanks for the tips! I know where to make the adjustments now. I saw a slight improvement going to 4 threads.
Hmmm. Maybe another memory purchase is in my near future!
