Wed, Nov 27, 4:51 AM CST
Subject: Posette2Eve Clothing Conversions
Starlok ( ) posted Mon, 04 June 2001 at 9:57 PM ยท edited Sat, 23 November 2024 at 6:57 PM
I recently DL'd the latest EVE Version and associated files...the problem: Whether I use MorphWorld,s Clothing pack or the "Cut & Paste" conversion process, something goes wrong. The clothes are fine when conformed, but go haywire when I attempt to pose EVE! See Associated JPG for Demonstration: All body part positions are Zeroed, All IK's on Miniskirt & EVE are off Miniskirt Conformed to EVE,then parented to BODY EVE hip bent to 16 degrees Any advice??? Starlok AtheldorJFC@AOL.Com
lalverson ( ) posted Mon, 04 June 2001 at 10:01 PM
personnally I haven't seen that, except for attenpting that on a system running the PPP and windows 2K. I was not able to do much about it. but I did send the modified cr2 to trav to look at. But on my home system I run 98 and PPP and don't have this trouble (except for if the colloars are bend backwards more than 7 degrees.
sinixyl ( ) posted Tue, 05 June 2001 at 1:23 AM
You are applying the pose to the clothes instead of the figure make sure you click on a part that is not covered by the clothes on the figure and then apply the pose.
mr_sanity ( ) posted Tue, 05 June 2001 at 2:02 PM
Hmm... I haven't seen this problem with the Posette to Eve clothes conversions. BUT, I did find a problem that caused me to get discouraged with the conversions. Apaprently, one of the forearms (I forget which one) does not work properly. If you ever try to scale the forearm of that clothing piece, it does not scale. I have seen it happen to the catsuit, and to numerous long-sleeved clothing items. mr. sanity
Starlok ( ) posted Tue, 05 June 2001 at 8:55 PM
Well, I've tried those but it seems that whenever the hip on eve is rotated or bent (and yes, i am using 4.03)everything goes kablooey! Thanks, but it seems that I'll either need to find some clothing designed especially for EVE or get used to her being a nudist...hmmm...ummm...
