Fri, Nov 22, 11:22 PM CST
Subject: Memory Wierdness with P7
AnAardvark ( ) posted Wed, 05 December 2007 at 8:56 PM · edited Fri, 22 November 2024 at 11:12 PM
I'm finding that on a particular scene, P7 will fail to load a texture map when rendering at the "final" setting, but will load it at two notches lower.
Also, is there configuration file which needs to be deleted if you've had a crash or two with P7? I remember that there was one with P6.
drifterlee ( ) posted Wed, 05 December 2007 at 10:18 PM
I have that happen. Try shutting Poser down and reopening, Sometimes you need to reboot your PC.
visque ( ) posted Thu, 06 December 2007 at 11:20 AM
I'm having a simular crash situation.  Do you know which file needs to be deleted?  It seems if a file crashes once that there is a large probability that it will crash again.
I've backed off firefly and tried rendering in p4, but I still get a message about reducing the demands of firefly.
I've only got a few hairs left to pull out.  Help.
