Tue, Nov 26, 1:07 PM CST
Bryce F.A.Q (Last Updated: 2024 Nov 26 10:16 am)
Subject: camera angles and magnifying glass - help
erosiaart ( ) posted Tue, 11 December 2007 at 9:29 PM · edited Fri, 08 November 2024 at 3:26 PM
strange thing happening...i've set my camera angle/ and used the nagifying glass to zoom to an object to texture it, work on it.
when i use the '- 'zoom magnifying glass to get it back to the angle it was at previously, the caera angle seeed to have oved.. and i have to play around with the camera angles to get it back to what it was..
help ...am i doing something wrong here?
i can't seem to do screen shots on y laptop.... otherwise i'd have showed you what i eant
help!
RodsArt ( ) posted Wed, 12 December 2007 at 1:15 AM
I always manually move to the angle and zoom I prefer and set the place markers....one for side, top, front, etc.
These place markers will also maintain focal changes too.
This also comes in handy when working on a particular item that I've moved way out of the scene to manipulate, remodel, ect.
Afterward you can ALT-click on the place markers and clear them for further use.
___
Ockham's razor- It's that simple
croowe ( ) posted Wed, 12 December 2007 at 1:24 AM
Not exactly sure why your camera angle would change after zooming back out unless you inadvertinely selected the camera while zoomed in and changed its position without knowing it. On the top left of the interface are 5 or 6 small beads (right beside the Nano Preview window if I remember correctly - dont have Bryce on my PC here at work) which you can select to remember your exact camera positioning. One thing I will always do before using the Zoom tool or playing around with different camera settings is to click one of  these. After your done editing in the Zoom mode and Zoomed back out, if your camera is not where it should be just click on that same bead and your exact camera positioning will be restored.
erosiaart ( ) posted Wed, 12 December 2007 at 2:17 AM
aha... thank you both of you.. dumb me wasn't doing that....
thanks a lot .. it's now getting back to the angle i chose!
cheers
