Forum Moderators: wheatpenny Forum Coordinators: bwsupport
Vue F.A.Q (Last Updated: 2026 Feb 27 3:10 pm)
Thanks for the info Dolly... I know how to bring in the picture into vue and all that... So, from the above explanation, are you telling me that by selecting mirror y that the picture will then come into view as you show in the upper picture, at a 90 degree angle to the ground plane?? What happens when I do it, the plane just lays flat on the ground... The when I try to put it straight, the controls in view just never put it exactly straight... That's my problem... :) Anyway, I'll try this mirror y thing and see if the picture comes out automatically at a 90 degree angle to the ground plane... Thanks..
Yes, they correspond, but it depends on how your object is positioned to start with. The 270 Pitch will work if you've just loaded the Plane and haven't done anything else with it. As you get the hang of using those controls, you won't need to worry about whether you've moved it around first or not, but just for starting, set the pitch first; then you can do other things with it. :) Bill, I'm using 3.1. I change my desktop colors by right-clicking the desktop, select Properties, then tab to Appearance. :)
"Damn-- I HATE having to go to work--- I miss out on ALL the fun!"...hee x2! Mike, don't work...Vue would keep you alive and happy, but no fix income though...like me, no money but happy....LOL! What is a "plene"...hee, hee..you got to be rushing and all excited about the fun here. Go to work now, the forum people would always accept late respond...errr...especially from a Mod Bull ;-)
Attached Link: http://www.irfanview.com/english.htm
LOL! Paul, Irfran View is a simple, small and free image viewer with some reasonable editing abilities. It's a pretty cool little program, really. I use Painter for serious editing and painting, but for those quick little fixes, such as rotating and greyscaling and making thumbnails, Irfan View rocks. Plus, you can view a whole folder of thumbnails all at once. Check the link out.Hey Mike, thanks for that suggestion.. I thought it was another vue feature, no joke... :) I was thiking to myself "Where is irfan view in this program?">.. Small thanks for the tips about upside down and y axis...So, far I haven't experienced that... Varian, I figured out the camera thing, I just experiemented till it looked like your image... And the plane definitely stands up straight at 270 degrees...
It's not that hard if you use the numeric editor. Let's say you have an 8 by 10 photo. Create your plane, then go to the size parameter and enter a value of .8 for the "X" axis and 1.0 for the "Y" axis. If you're dealing in pixels, it's just as easy. 800 wide by 600 high would be .8 on the "X" axis by .6 on the "Y" axis. Once the proportions are correct, you can resize the whole plane as needed. -SMT
Yup, Dolly and Steve have the way of it. Either eyeball it or measure it. :) Chances are I'll make the picture square either by cropping or adding material. The easiest way to follow this route is to square your image by filling extra space with black -- in a paint program. Then you will also need to make an alpha mask to match (with the image area black and the filled area white). The alpha would be loaded in the transparency channel of your image material. Settings to 100% transparency and check "Variable" to open the function for adding the alpha image. :)
You follow me like a tiger Varian... :) That was precisely what I was going to do... But I thank you for saying it anyway, cause there is going to be that time where I don't know and you will... :) Steve, thanks for that explanation regarding the measurements.. I will try it tonite and see if I save myself some work... I was trying it last night, just experimenting, but it wasn't coming out to good.. Maybe it'll work today... :)
Let's say you create a plane in vue... To this you're going to assign a picture... Now you have your plane with a picture on it... How do you position the plane so that the picture is right side up? The device for moving stuff in vue is very awkward, and using the numbers on the side doesn't help any... Anybody know a way to guarantee a picture will be right side up when you bring it into a plane??? Any info appreciated, thanks...
