Fri, Nov 22, 11:46 PM CST
Subject: Cross talk in P7
AnAardvark ( ) posted Fri, 14 December 2007 at 5:36 PM · edited Fri, 22 November 2024 at 8:18 PM
I'm having problems with cross-talk in P7 for V3 SAE's body. (Not her head). Basically, if she's the second mil figure I load, she won't take any body FBMs. Is there any trick to avoiding this?
thanks
SamTherapy ( ) posted Fri, 14 December 2007 at 7:00 PM
That's not crosstalk but it's a well known problem with INJ tech in all versions of Poser.  You have to INJ each figure separately, save then reload.
AnAardvark ( ) posted Fri, 14 December 2007 at 11:38 PM
Quote - That's not crosstalk but it's a well known problem with INJ tech in all versions of Poser.  You have to INJ each figure separately, save then reload.
Do you save and reload after each figure?
SamTherapy ( ) posted Sat, 15 December 2007 at 8:28 AM
Quote - > Quote - That's not crosstalk but it's a well known problem with INJ tech in all versions of Poser.  You have to INJ each figure separately, save then reload.
Here's how it should go:
Start with an empty scene
Bring in your figure
INJ the morphs
Save the figure
Clear the workspace
Start at the beginning until you have created all the characters you need.
AnAardvark ( ) posted Sat, 15 December 2007 at 10:47 AM
OK, sounds good.
raven ( ) posted Sat, 15 December 2007 at 2:26 PM
Attached Link: Figure Independent Injections thread.
There is a way to allow second or third figures to have the INJ poses work on the specific figure without having to save/reload but it requires a bit of jiggery-pokery. I have done it to all my INJ poses.
