Fri, Jan 10, 7:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Help with invisible model
keppel ( ) posted Sun, 16 December 2007 at 5:49 AM · edited Mon, 23 December 2024 at 6:54 AM
I have a created a model that has been rigged, and I have checked that everything (.obj and cr2) functions as it should.  I have uvmapped the rigged .obj in Bodypaint 3D V3.  When I replace the original .obj with the uvmapped .obj and then load the model into Poser the model is invisible.  All the body parts, material zones and dials are present just the model is invisible.  If I import the .obj through File>Import>Wavefront obj the model appears as it should so I suspect that some how there has been a breakdown in the referencing from the cr2 to the .obj.  Can anyone offer some suggestions on how to fix this problem?
Shane
My Renderosity Store
Virtual Furnishing
My Portfolio
nruddock ( ) posted Sun, 16 December 2007 at 6:07 AM
Sounds like the group names have altered so that they no longer match those specified in the CR2.
richardson ( ) posted Sun, 16 December 2007 at 6:50 AM
bmark
keppel ( ) posted Sun, 16 December 2007 at 7:35 AM
nruddock,
Thanks for your quick reply.  You are correct.  On closer examination of the .obj file in wordpad it appears that Bodypaint inserts an underscore in place of a space at the end of the group name.  Editing all instances of this change seems to have corrected the problem.  Thanks again for your help.
Shane
Virtual Furnishing
My Portfolio
