Forum Moderators: Staff
The MarketPlace Wishing Well F.A.Q (Last Updated: 2025 Jan 06 1:53 am)
Have an idea for a MarketPlace product? Would you like to let the MarketPlace Merchants know?
This is the place!
Make sure you check The Product Showcase Forum and The Product Showcase Art Gallery.
Attached Link: Unicornst & RubyT's Store
**I'm going to toot my horn a bit here.Have you looked at Bryce, Shadow and Whisper in mine and RubyT's store? Bryce and Shadow are for V4. Whisper is for SP3, but her textures can be placed on Aiko. You just have to place two areas manually.**
**Go ahead and apply as you normally would to V3 or SP3 (wiht the MAT pose). Then you need to go into the material room (if you're using Poser5 up) and look for the two areas that don't have the skin applied. Knees and thighs, I believe (it's been awhile). Just turn the surface color to white and then add on the skin texture there. If you're still not sure (or I wasn't clear enough), look at another surface, such as the torso, and see how it's set up. Fairly easy to do.
If you're using Studio, even easier. Go to your Surface tab....select the Knees and Thigh, change diffuse to white and add on the body texture with the drop down menu under the diffuse color.
I had thought to mention Mairwen, but wasn't sure her skins were what you looking for. Good news is that her skins are set up to apply with one click. grin
Thanks so much for the compliment!**
I uploaded a couple for A3 & V4 a few days ago to freestuff, not really fairy, but they may help you.
The best & most beautiful
things in the world cannot be seen nor touched... but felt in the
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
Quote - **Go ahead and apply as you normally would to V3 or SP3 (wiht the MAT pose). Then you need to go into the material room (if you're using Poser5 up) and look for the two areas that don't have the skin applied. Knees and thighs, I believe (it's been awhile). Just turn the surface color to white and then add on the skin texture there. If you're still not sure (or I wasn't clear enough), look at another surface, such as the torso, and see how it's set up. Fairly easy to do.
I've tried Whisper and Shadow out, and they both look great! Your instructions really helped and were easy to follow. Thank you! You and Ruby should consider making one big second skin package like Angelmoon's Zenia pack.
I don't particularly care if they're included in a character package or alone but I would really like to have more fairy and other fantasy second skins for A3 and V4. Please! :D
