Mon, Feb 17, 6:48 PM CST
Forum Moderators: RedPhantom
Subject: Mike 3 geometries
chamba ( ) posted Fri, 28 December 2007 at 2:18 PM · edited Tue, 15 October 2024 at 5:31 PM
I can't open my mike 3 figure. when it is attempted a message states that geometries/ dazpeople/ milman/obj unable to open. I have checked geometries and the file is there. i uninstalled and reinstalled the figure, but it still will not work.  I recently changed to a new computer that has vista, could it be the problem? I never had a problem on my old computer.  My v3 figure operates fine.
I use poser artist are there any sugesstions?
Miss Nancy ( ) posted Fri, 28 December 2007 at 2:29 PM
do they have file permissions problems associated with vista?
flibbits ( ) posted Fri, 28 December 2007 at 11:19 PM
I have a weird problem with M3 that when the DAZ morphs are applied and any muscle dialed in, the left arm is warped.  I even applied the update, but that didn't help.
SamTherapy ( ) posted Fri, 28 December 2007 at 11:25 PM
Quote - I have a weird problem with M3 that when the DAZ morphs are applied and any muscle dialed in, the left arm is warped.  I even applied the update, but that didn't help.
I believe there are two updates and both need to be installed in order to correct the errors.
steveshanks ( ) posted Sat, 29 December 2007 at 5:00 AM
Chamba which version of poser are you using......Steve
chamba ( ) posted Sat, 29 December 2007 at 1:58 PM
I am using poser4/artist.
steveshanks ( ) posted Sat, 29 December 2007 at 2:05 PM
Ah all has become apparant LOL, go to
Poser 4RuntimeGeometriesDAZPeople
and you'll see a file called
blMilMan_m3.rsr
sitting next to
blMilMan_m3.obj
this rsr file is the fast loading version of the obj, so delete it then next time you add Mike 3 to the scene he will load a little slow because poser will be building you a new rsr file, sometimes the rsr file gets corrupt, so first thing to check is delete the rsr, P5 and up don't use the rsr files.......Do as SamTherapy says to fix your arm problem and your good to go........Steve
chamba ( ) posted Sun, 30 December 2007 at 12:39 AM
thanks i will delete it.  it worked by the wa. the arm problem was someone else.
