3 ways for doing this.
Simplest way: use the basic material editor, and in the transparency slot, load in your transmap.
Hard way1: in the advanced mat editor, right click the colour production function, then in the function editr, add a texrture map input node, load in your transmap, and connect the node to the alpha output.
Hard way2: advanced mat editor, transparency tab, se transparency to 100% and check variable transparency. Right click the transparency production sphere, and connect your transmap to the transparency output.
I am using Vue6 Esprit. I am tring to make a cylinder with text on a transparent background.
The label is made in photoshop. I have saved it in every format I can think of and no alpha is coming with it. I made my own alpha for it but can't find where to put it in the material editor.
It is something very simple and I know I will go 'duh!' when i find out how to do it.
Any ideas?
