Tue, Jan 28, 4:21 AM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: Photoshop weird color problems
KeremGogus ( ) posted Sun, 30 December 2007 at 11:26 AM · edited Tue, 14 January 2025 at 7:47 PM
Hello friends,
I have weird color issues on Photoshop. When I opened a regular terragen render on 8 bit bmp format and applied brightness contrast, auto colors and levels - saw that the colors are looking like "web colors". All colors passings are visible.  And Graident layer I applied on Photoshop looks like that too.
I attached a screen shot - I hope you can see it and give a helping hand to fix this.
Thanks in advance
link to screen shot
karosnikov ( ) posted Thu, 03 January 2008 at 12:51 AM
. **The effect you see is sometimes called banding,** I dont think it's a problem with the display. I think it's the interaction between the layers. When I make a gradient in PS I tend to put "Dither" on. it  scatters the colours a little more.. the example shows a red-green dither. the effect is almost impossible to detect when the colours are so similar, having a dither in your gradient would minimise banding.
I would also try to avoid having exactly the same (duplicate/clone) gradient effecting another try shifing the effect a pixel or two across, this might reduce funky colour intereaction.
See if you can add little noise to the gradient, or have a look also in the render options in the  3D program, a bit of difusion in the sky could work wonders.
KeremGogus ( ) posted Thu, 03 January 2008 at 5:39 AM
Thank you so much dear friend - this will help
thundering1 ( ) posted Thu, 03 January 2008 at 6:38 AM
"See if you can add little noise to the gradient, or have a look also in the render options in the  3D program, a bit of difusion in the sky could work wonders."
Yes, this is a common problem with large areas and a fine gradient - you often get banding of colors since it's changing only teeny amounts of shade or hue/value spread over a failry large area.
Along with adding some grain, then do a slight Gaussian Blur (just a pixel or two) and it will look like a better blend.
Hope this helps-
-Lew ;-)
KeremGogus ( ) posted Thu, 03 January 2008 at 8:44 AM
Sure guys - these tricks helped a lot. Thanks a million...
