Sun, Feb 9, 11:04 PM CST
Subject: V3 and Morph Injections and Body Injections
ladyperiwinkle ( ) posted Sun, 06 January 2008 at 6:34 AM · edited Sun, 09 February 2025 at 11:00 PM
Here I go again needing some help. I have Poser 7 and I bought the head and body morphs to go with V3, now problem is I purchase  Elegant Elizabeta for V3 from the store here, I can do the makeup part but when I hit the head and body morph, it does not work , this seems to be the case in all the V3 charcters I buy. Now I thought when I purchased the head and body morphs, that everything came with it. What am I doing wrong, or what I am buying or bought is not right?
Valerian70 ( ) posted Sun, 06 January 2008 at 7:29 AM
What happens when you try to inject the V3 morph into the base?
Does it give an error message or just appear to hang?
The Head and Body Morphs for V3 MUST be installed in your main Runtime, well the !DAZ folder that is housed under libraries must be or else Poser just doesn't like it.
ladyperiwinkle ( ) posted Sun, 06 January 2008 at 8:46 AM
It just hangs for a while like its locked up then it wants me to search for the files, in which I do and then it states that it is not a valid poser file, I bought the V3 head and body morphs from Daz. so I know it is valid. They are imputed in to Poser 7, the files are there I did it myself. Do you think that I don't really have all the files that it needs to run the morphsfrom the package I bought, if so, then where do I fine them.
Valerian70 ( ) posted Sun, 06 January 2008 at 11:10 AM
Is the !DAZ folder just under the main Libraries listing?
It has to be there and not under another subfolder.  If you have got it in any other location then this could be causing the problem.
You also have files that begin !V3 in your Pose folder, these are in the correct place.
