Fri, Jan 31, 7:32 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
Subject: Extracting Object from PP2
nyguy ( ) posted Tue, 08 January 2008 at 10:56 AM · edited Fri, 31 January 2025 at 7:32 AM
I am working on a prop and created a PP2 but when I opened the PP2 file there is no reference to to the object file. Is there a way to extract the object file from the pp2 file?
Poserverse The New Home for NYGUY's Freebies
Paloth ( ) posted Tue, 08 January 2008 at 11:14 AM
Have you tried changing the .pp2 extension to .obj?
svdl ( ) posted Tue, 08 January 2008 at 11:23 AM
THere is.
First, load your .pp2 in Poser. Immediately go to File ->Export -> Wavefront .OBJ. Select the options to keep the group names. Save the .OBJ at a meaningful location.
Next, open the .pp2 file in a CR2 editor (I use kim99's free CR2Builder, available from www.3minutesposer.com
Expand the tree, and delete the entry "geomCustom"
In place of "geomCustom", you need an entry "storageOffset 0 0.3784 0"
and on the next line: "objFileGeom 0 0 "...<path to your saved .OBJ file>..."
If you want to have a peek at .pp2s that work with external geometries, download my V4 Warrior freebie and look at the props in there.
My gallery   My freestuff
nyguy ( ) posted Wed, 09 January 2008 at 6:11 AM
Here is the problem I ran into. Exported the obj files as suggested, edited the PP2 in notepad plus and saved the file with a different file name. When I opened in Poser it was small, about the size of a matchbox car compared to M3.
svdl ( ) posted Wed, 09 January 2008 at 6:21 AM
Reload the new prop, and set its scale to 100%, then resave. It'll keep the external .OBJ reference.
nyguy ( ) posted Wed, 09 January 2008 at 6:30 PM
I am looking into something else at this point. I found a Python script that might work and will be testing it later.
mrsparky ( ) posted Wed, 09 January 2008 at 6:52 PM
Attached Link: http://market.renderosity.com/mod/bcs/index.php?ViewProduct=37406
If you don't mind paying for a easy to use commerical product, try the Tool Collection for Poser by Dimension3D (link above). Extracted everything OK I've ever thrown at it.
kuroyume0161 ( ) posted Wed, 09 January 2008 at 9:28 PM
I go with Paloth.  You then remove the geomCustom section from the pp2 file and insert the reference as svdl illustrates.  Voila.  Why do this the difficult way?  The stuff between the { } after the geomCustom is basically a Wavefront OBJ format just sitting there.  Remove the num... lines (or comment out with //) and you have an external obj file.
Add something like this in place of the geomCustom section (of course, change the file path to match the new obj file):
storageOffset 0 0.3487 0
objFileGeom 0 0 :Runtime:Geometries:ZygoteCostumes:Hats:blRHCap.obj
 -- Bjarne Stroustrup
